Visitor razayasar
/bin/bash: gmake: command not found when creating hardware platform & BSP in SDK 2013.4
I am using Xilinx SDK version 2013.4
I am trying to create an application..
After selection of .xml file to create hardware platform, i got this message on console of SDK
12:28:17 **** Build of project standalone_bsp_2 ****
make -k all
libgen -hw ../hw_platform_0/system.xml\
           -pe ps7_cortexa9_0 \
           -log libgen.log \
           system.mss
libgen
Xilinx EDK 2013.4 Build EDK_2013.4.20131205
Copyright (c) 1995-2012 Xilinx, Inc.  All rights reserved.
Command Line: libgen -hw ../hw_platform_0/system.xml -pe ps7_cortexa9_0 -log
libgen.log system.mss
Staging source files.
Running DRCs.
Running generate.
Running post_generate.
Running include - 'gmake -s include "COMPILER=arm-xilinx-eabi-gcc"
"ARCHIVER=arm-xilinx-eabi-ar" "COMPILER_FLAGS= -O2 -c"
"EXTRA_COMPILER_FLAGS=-g"'.
ERROR:EDK -  make failed for target "include"
ERROR:EDK - Error(s) while running make.
make: *** [ps7_cortexa9_0/lib/libxil.a] Error 2
make: Target `all' not remade because of errors.
12:28:22 Build Finished (took 4s.827ms)
After that when i tried to create BSP, i got this on console.. (plz find attachment Screenshot)..
i tried these steps 3 times, but the error occours.
and i am following this tutorial pg 3 to 7.(find the attachment .pdf file).
Re: /bin/bash: gmake: command not found when creating hardware platform & BSP in SDK 2013.4
Can you check the below forums post which was accepted as solution http://forums.xilinx.com/xlnx/board/crawl_message?board.id=ELINUX&message.id=5598
Achutha
Achutha
Visitor razayasar
Thanx achutha..
now i am getting this after executing your command....
17:58:08 **** Incremental Build of configuration Debug for project Hello_World ****
make all
Building file: ../src/platform.c
Invoking: ARM gcc compiler
arm-xilinx-eabi-gcc -Wall -O0 -g3 -c -fmessage-length=0 -I../../standalone_bsp_0/ps7_cortexa9_0/include -MMD -MP -MF"src/platform.d" -MT"src/platform.d" -o "src/platform.o" "../src/platform.c"
In file included from ../src/platform.c:42:0:
../../standalone_bsp_0/ps7_cortexa9_0/include/xparameters.h:15:28: fatal error: xparameters_ps.h: No such file or directory
compilation terminated.
make: *** [src/platform.o] Error 1
17:58:08 Build Finished (took 112ms)
