/bin/bash: gmake: command not found
How do you set and where do you set in the SDK 14.4 the gmake path? I'm trying to port a project from windows environment to Linux Ubuntu and have run into this error.
After some digging I found the answer in another post.  The problem is that Ubuntu doesn't supply gmake, only make so enter the following command: sudo ln -s /usr/bin/make /usr/bin/gmake and you'll be able to compile your bsp.
Advisor
Advisor
Thanks, this fixed my problem in SDK 2013.4!
DSP in hardware and software
great that was quick!.. thanks for posting the solution.
I had this problem with SDSOC 2015.2 running ubuntu 14.04
Thankssssssssssssssssssssssssssss aloooooooooot man. I have been through this problem for couple of days and just now I could solve it by adding this line. Thank you.
