swally
/bin/bash: gmake: command not found
How do you set and where do you set in the SDK 14.4 the gmake path? I'm trying to port a project from windows environment to Linux Ubuntu and have run into this error.
swally
After some digging I found the answer in another post.  The problem is that Ubuntu doesn't supply gmake, only make so enter the following command: sudo ln -s /usr/bin/make /usr/bin/gmake and you'll be able to compile your bsp.
swally
pedro_uno
Advisor
Advisor
Thanks, this fixed my problem in SDK 2013.4!
DSP in hardware and software
laursand
great that was quick!.. thanks for posting the solution.
gorker
I had this problem with SDSOC 2015.2 running ubuntu 14.04
abdelsalam
Thankssssssssssssssssssssssssssss aloooooooooot man. I have been through this problem for couple of days and just now I could solve it by adding this line. Thank you.
