bitbake command is not working
Hi ,
I am using a  petalinux version : 2017.3 , while running the below command
bitbake -c compile device-tree-generation
ERROR:
Loading cache: 100% |#########################################################################################################################################################| Time: 0:00:03
Loaded 3255 entries from dependency cache.
Parsing recipes: 100% |#######################################################################################################################################################| Time: 0:00:01
Parsing of 2463 .bb files complete (2461 cached, 2 parsed). 3256 targets, 225 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.32.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "aarch64-xilinx-linux"
MACHINE = "zcu102-zynqmp"
DISTRO = "petalinux"
DISTRO_VERSION = "2017.3"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta
meta-poky = "rel-v2017.3:b37e6d969f27d92ef8b323678598c4ad879243c3"
meta-perl
meta-systemd
meta-gpe
meta-python
meta-efl
meta-ruby
meta-filesystems
meta-gnome
meta-multimedia
meta-networking
meta-webserver
meta-xfce
meta-initramfs
meta-oe = "rel-v2017.3:a9887ac249b81fcac3007244d0c807c71b73acef"
meta-linaro-toolchain = "rel-v2017.3:39860f6c7af0858981cc004bbe4f4c421f6be607"
meta-qt5 = "rel-v2017.3:eec778bfb9a0b5494d593a2d7bb02c027b641835"
meta-xilinx = "rel-v2017.3:04a45809e0bc42b35c88f8a08305d82fd25e97cf"
meta-xilinx-tools = "rel-v2017.3:37eff634934efac72d3e2eabb7c4f8d0c8a36fbb"
meta-petalinux = "rel-v2017.3:d74ceaef26e606c2761edfc3446d0ad3c3cc8b8e"
meta-virtualization = "rel-v2017.3:cbfd4376d5e9d229f857151ffdfb57fbc6c0c40d"
meta-openamp = "rel-v2017.3:cfeca8988418e4967f0d6df828d23a1540ae25a0"
Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:01
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: external-hdf-1.0-r0 do_deploy: Function failed: do_deploy (log file is located at /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/log.do_deploy.6926)
ERROR: Logfile of failure stored in: /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/log.do_deploy.6926
Log data follows:
| DEBUG: Executing python function sstate_task_prefunc
| DEBUG: Python function sstate_task_prefunc finished
| DEBUG: Executing shell function do_deploy
| sudo: no tty present and no askpass program specified
| WARNING: /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/run.do_deploy.6926:1 exit 1 from 'install -d /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/deploy-external-hdf'
| ERROR: Function failed: do_deploy (log file is located at /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/log.do_deploy.6926)
ERROR: Task (/home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/sources/core/../meta-xilinx-tools/recipes-bsp/hdf/external-hdf.bb:do_deploy) failed with exit code '1'
NOTE: Tasks Summary: Attempted 387 tasks of which 386 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Please help
