doreenyen
blink: no symbol version for module_layout
Has anybody succeeded  to insmod blink.ko onto Zynq running Ubuntu ?
What is the remedy for the dmesg below ?
dmesg has,
Googling for this message finds recommended remedy is:
make -C /lib/modules/`uname -r`/ M=`pwd` modules
but the git clone linux has no directory lib/modules/`uname -r`
whilst ug873-design-files Makefile has,
KER_DIR := /home/doreen/Xilinx/gitLinux/linux-xlnx
all:
    make ARCH=$(ARCH) -C $(KER_DIR) M=$(PWD) modules
    At the linux-xlnx directory of the Ubuntu kernel:
      cp ./arch/arm/configs/xilinx_zynq_defconfig .config
       make oldconfig
    make prepare
    make modules
$ make modules
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
  CALL    scripts/checksyscalls.sh
  Building modules, stage 2.
  MODPOST 20 modules
The module was built with the kernel sources version matching the running kernel.
# uname -r
3.8.0-xilinx-00015-gabc285b      # modinfo blink.ko
filename:       blink.ko
license:        GPL v2
description:    Xilinx Blink Driver
author:         Doreen Yen
depends:
vermagic:       3.8.0-xilinx-00015-gabc285b SMP preempt mod_unload modversions ARMv7 p2v8
dogbytes
doreenyen
To fix the subject line message, copied from the board, /proc/config.gz to the root of the linux sources, directory linux-xlnx
zcat config.gz > .config
make oldconfig
make prepare
make ARCH=$ARCH CROSS_COMPILE=$CROSS_COMPILE uImage
make modules
cd to your directory having blink.c
make ARCH=$ARCH CROSS_COMPILE=$CROSS_COMPILE clean
scp blink.ko to your board, ~/App/
# insmod blink.ko
Happily, no error message and it is there,
# lsmod
Module                  Size  Used by
blink                   2011  0
ipv6                  227727  20
dogbytes
doreenyen
make oldconfig
make prepare
make modules
# insmod blink.ko
# lsmod
Module                  Size  Used by
blink                   2011  0
ipv6                  227727  20
dogbytes
doreenyen
Oh yeah, the printk messages of the init_module are not output to serial console,
dmesg |tail
dogbytes
doreenyen
Hey, use the zc706-bist system.bit and change blink.c address was for zc702, instead use for zc706,
#define BLINK_CTRL_REG     0x41220000
the address is found in the
/zc706_bist.sdk/SDK/SDK_Export/zynq_fsbl_bsp/ps7_cortexa9_0/include/xparameters.h
Then blink.ko and linux_blinkleds_app will give you the console menu to turn LED_0 on with a 1, off with a 0, and some other digit to quit the menu, eg. 2, the comment in the code about 0 quitting menu is wrong.
dogbytes
