Visitor hjo
boot problem with xilinx master-next on Zedboard
Hello
After I got can4linux working months ago with kernel 3.6 outside the kernel tree
I now want to port the can4linux to the latest kernel tree (drivers/char/can4linux). I downloaded and configured the kernel using:
make ARCH=arm clean
make ARCH=arm xilinx_zynq_defconfig
make ARCH=arm UIMAGE_LOADADDR=0x8000 uImage
the kernel compiles and loads from u-boot, but stops very early:
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.10.0-xilinx-14840-g5ad0256-dirty (oe@heinz.site) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-49) ) #12 SMP PREEMPT Wed Aug 7 19:04:59 CEST 2013
Machine: Generic DT based system, model: Xilinx Zedboard
bootconsole [earlycon0] enabled
cma: CMA: reserved 16 MiB at 1e800000
Memory policy: ECC disabled, Data cache writealloc
--- here it stops ---
What can be the reason for stopping that early? I hope someone hast the answer.
Is there a special config file available for the Zedboard?
Heinz
Tags (3)
Visitor hjo
Re: boot problem with xilinx master-next on Zedboard
Hello
I used
./arch/arm/boot/dts/zynq-zed.dts
and got the error message
xemacps e000b000.ps7-ethernet: eth0: no PHY found
After changing the mdio section in the Ethernet description my kernel boots up with the rootfs mounted via nfs.
 Heinz
master-next with the xilinx_zynq_defconfig is supposed to work, and I just double checked: It boots fine here.
Make sure though, that you also use the DT blob coming with the kernel tree when you replace your kernel.
Visitor hjo
Thanks will check that tomorrow.
Heinz
Visitor hjo
Hello
I used
 Heinz
Scholar vanmierlo
So what did you change to make it work exactly? Stating that you changed something doesn't really help.
Visitor nocomer
I believe, it was smth. like replacing phy@7 with phy@0
And this change is not master-next specific
Visitor hjo
That is what I'm using
ps7_ethernet_0: ps7-ethernet@e000b000 {
            #address-cells = <1>;
            #size-cells = <0>;
            clock-names = "ref_clk", "aper_clk";
            clocks = <&clkc 13>, <&clkc 30>;
            compatible = "xlnx,ps7-ethernet-1.00.a";
            interrupt-parent = <&ps7_scugic_0>;
            interrupts = <0 22 4>;
            local-mac-address = [00 0a 35 00 00 00];
            phy-handle = <&phy0>;
            phy-mode = "rgmii-id";
            reg = <0xe000b000 0x1000>;
            xlnx,enet-reset = <0xffffffff>;
            xlnx,eth-mode = <0x1>;
            xlnx,has-mdio = <0x1>;
            xlnx,ptp-enet-clock = <111111115>;
            mdio {
                #size-cells = <0>;
                phy0: phy@0 {
                    compatible = "marvell,88e1510";
                    device_type = "ethernet-phy";
                    reg = <0x0>;
                    marvell,reg-init = <0x3 0x10 0xff00 0x1e 0x3 0x11 0xfff0 0xa>;
Visitor portolan
I just found the exact same problem after updating the kernel tree this morning: zynq-zed.dtsis broken, to work Ethenert needs needs the correction in the previous post to work. I made the corrections and now it work perfectly!
Is it possible to push this update to the git tree?
Michele
Visitor portolan
BTW, the devicetree.dtb in the 14.7 official release suffers from the same problem: Ethernet won't work on it
It looks like there have been changes between Zed board revisions: https://lists.yoctoproject.org/pipermail/meta-xilinx/2013-November/000249.html .
If possible it would be nice to get a picture of the situation. Could people please post their Zed revision and the statuf of Ethernet functionality for different phy addresses (looks like 7, 1 and 0 are supposed to be the relevant ones)?
But it might be the case that a single file is not able to serve all Zed revisions.
Visitor hjo
used with Zedboard PB200-248 Rev C
Visitor nocomer
I used phy@0 with Zedboard PB200-248 Rev. D and it worked for me.
phy@7 did not work and I never tried phy@1
Also, as I know, phy@0 is used in .dtb shipped with this board by Digilent
I have only rev C boards here. And those respond to address 0 but not 1 or 7. Anybody has a pre rev C board?
The phy-address is changed to zero in the latest sources https://github.com/Xilinx/linux-xlnx/commit/9a3832f0ac6fa697d4c7798970ba14a3bfed5517 . I hope that works for the majority and does not lead to plenty of people complaining that we broke boards that work with 7 as phy-address.
