Observer alxn
bootgen: Initialization Pairs and the INT File Attribute
ug821-zynq-7000-swdev.pdf has this section:
A.3 Initialization Pairs and the INT File Attribute
And states:
Bootgen supports a fully C/C++ compatible preprocessor and all of the directives. It also supports expansion macros with parameters. Parameters can be passed on the Bootgen command line with the -D option that is compatible with GCC, and acts like #define
 For example:
#include "register_defs.h"
.set. kBAUD_RATE_REG = (k9600BAUD | kDOUBLE_RATE) << BAUD_BITS;
But when I put just:
#define XPS_QSPI_BASEADDR 0xE000D000
.set. XPS_QSPI_BASEADDR = 0x01020304;
$ bootgen -image boot.bif -o BOOT.bin -w on
WARNING: bad character '# at qspi_regs.int:1.1
WARNING: bad character 'd at qspi_regs.int:1.1-2
WARNING: bad character 'e at qspi_regs.int:1.1-3
WARNING: bad character 'f at qspi_regs.int:1.1-4
WARNING: bad character 'i at qspi_regs.int:1.1-5
WARNING: bad character 'n at qspi_regs.int:1.1-6
WARNING: bad character 'e at qspi_regs.int:1.1-7
WARNING: bad character 'X at qspi_regs.int:1.9
WARNING: bad character 'P at qspi_regs.int:1.9-10
WARNING: bad character 'S at qspi_regs.int:1.9-11
WARNING: bad character '_ at qspi_regs.int:1.9-12
WARNING: bad character 'Q at qspi_regs.int:1.9-13
WARNING: bad character 'S at qspi_regs.int:1.9-14
WARNING: bad character 'P at qspi_regs.int:1.9-15
WARNING: bad character 'I at qspi_regs.int:1.9-16
WARNING: bad character '_ at qspi_regs.int:1.9-17
WARNING: bad character 'B at qspi_regs.int:1.9-18
WARNING: bad character 'A at qspi_regs.int:1.9-19
WARNING: bad character 'S at qspi_regs.int:1.9-20
WARNING: bad character 'E at qspi_regs.int:1.9-21
WARNING: bad character 'A at qspi_regs.int:1.9-22
WARNING: bad character 'D at qspi_regs.int:1.9-23
WARNING: bad character 'D at qspi_regs.int:1.9-24
WARNING: bad character 'R at qspi_regs.int:1.9-25
ERROR:BootGen - syntax error
Line #1, "qspi_regs.int".
... 0xE000D000
