Visitor soischshald
booting linux on ZYNQ
Hi everybody,
I try to boot linux on our custom board. U-boot is running and linux starts to boot but did not finish. Below is the trace of the booting phase. As you can see it stops at "Registering SWP/SWPB emulation handler". Can someone give me a hint what is the problem here and how to solve it.
Best regads!
zynq-uboot> bootm 0x3000000 0x2000000 0x2a00000
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-4.0.0-xilinx-00020-g5b3c91
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3265824 Bytes = 3.1 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
   Image Name:
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    5289445 Bytes = 5 MiB
   Load Address: 00800000
   Entry Point:  00800000
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x2a00000
   Loading Kernel Image ... OK
   Loading Ramdisk to 1ee09000, end 1f3145e5 ... OK
   Loading Device Tree to 1ee02000, end 1ee08803 ... OK
Starting kernel ...
Linux version 4.0.0-xilinx-00020-g5b3c91b-dirty (<myPC>-VirtualBox) (gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-12ubuntu1) ) #13 SMP PREEMPT Wed Dec 2 10:30:58 CET 2015
Machine model: Zynq ZC702 Development Board
cma: Reserved 16 MiB at 0x1dc00000
Memory policy: Data cache writealloc
PERCPU: Embedded 11 pages/cpu @dfbcb000 s12672 r8192 d24192 u45056
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw earlyprintk
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 491412K/524288K available (4432K kernel code, 208K rwdata, 1520K rodata, 220K init, 193K bss, 16492K reserved, 16384K cma-reserved, 0K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc05d850c   (5954 kB)
      .init : 0xc05d9000 - 0xc0610000   ( 220 kB)
      .data &colon; 0xc0610000 - 0xc06440e0   ( 209 kB)
       .bss : 0xc06440e0 - 0xc0674654   ( 194 kB)
        Additional per-CPU info printed with stalls.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
slcr mapped to e0804000
zynq_clock_init: clkc starts at e0804100
Zynq clock init
sched_clock: 64 bits at 332MHz, resolution 3ns, wraps every 3311470116864ns
timer #0 at e0808000, irq=17
Calibrating delay loop... 1325.46 BogoMIPS (lpj=6627328)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x42e560 - 0x42e5b8
Brought up 2 CPUs
SMP: Total of 2 processors activated (2650.93 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
zynq-gpio e000a000.gpio: could not find pctldev for node /amba/slcr@f8000000/pinctrl@700/gpio0-default, deferring probe
platform e000a000.gpio: Driver zynq-gpio requests probe deferral
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0880000
vgaarb: loaded
SCSI subsystem initialized
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Switched to clocksource arm_global_timer
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 5168K (dee09000 - df315000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
io scheduler noop registered
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 27, base_baud = 3125000) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to e086a000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
m25p80 spi0.0: found n25q128a13, expected n25q128a11
m25p80 spi0.0: Controller not in SPI_TX_QUAD mode, just use extended SPI mode
m25p80 spi0.0: n25q128a13 (16384 Kbytes)
5 ofpart partitions found on MTD device spi0.0
Creating 5 MTD partitions on "spi0.0":
0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
0x000000100000-0x000000600000 : "qspi-linux"
0x000000600000-0x000000620000 : "qspi-device-tree"
0x000000620000-0x000000c00000 : "qspi-rootfs"
0x000000c00000-0x000001000000 : "qspi-bitstream"
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: no PHY found
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
ehci-pci: EHCI PCI platform driver
e0002000.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.0: unable to init phy: -110
ci_hdrc: probe of ci_hdrc.0 failed with error -110
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 24
pca954x 0-0074: probe failed
Xilinx Zynq CpuIdle Driver started
platform leds: Driver leds-gpio requests probe deferral
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
TCP: cubic registered
Teacher muzaffer
Re: booting linux on ZYNQ
you can use the dtc program to convert dtb file back to a dts file which shows you what devices are enabled. Then you can diff working & non-working dts files to see what the difference is and which device is causing the failure. You need to debug the source of the failure when you identify the device which is responsible.
Visitor soischshald
Hi everybody,
sadly I do not know the detail but I found out the problem comes from the .dtb file. I try some of them and one does work. These is good because Linux comes up and is running on our custom board. Nevertheless it would be great if someone can give me hint's about the .dtb file. For example how can I modify it?
Best regards!
Teacher muzaffer
