build error in sdk 2017.1
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function do_configure
| MISC_ARG is  -yamlconf /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/plnx_aarch64-xilinx-linux/pmu-firmware/2017.1+gitAUTOINC+3813f14966-r0/pmu-firmware.yaml
| APP_ARG is  -app "ZynqMP PMU Firmware"
| cmd is: xsct /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/plnx_aarch64-xilinx-linux/pmu-firmware/2017.1+gitAUTOINC+3813f14966-r0/app.tcl -ws /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/../components/plnx_workspace -pname pmu-firmware -rp /opt/pkg/tools/hsm/data/embeddedsw -processor psu_pmu_0 -hdf /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/deploy/images/plnx_aarch64/Xilinx-plnx_aarch64.hdf -arch 32  -app "ZynqMP PMU Firmware"  -yamlconf /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/plnx_aarch64-xilinx-linux/pmu-firmware/2017.1+gitAUTOINC+3813f14966-r0/pmu-firmware.yaml
| Starting xsdk. This could take few seconds... Eclipse:
| An error has occurred. See the log file
| /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/components/plnx_workspace/.metadata/.log.
| XSCTHELPER INFO: Empty WorkSpace
| timeout while establishing a connection with SDK
|     while executing
| "error "timeout while establishing a connection with SDK""
|     (procedure "getsdkchan" line 111)
|     invoked from within
| "getsdkchan"
|     (procedure "::sdk::set_user_repo_path_sdk" line 16)
|     invoked from within
| "::sdk::set_user_repo_path_sdk $params(set)"
|     (procedure "repo" line 27)
|     invoked from within
| "repo -set $path"
|     invoked from within
| "if { $params(ws) ne "" } {
|     #Local Work Space available
|     setws $params(ws)
|     if { [catch {importprojects $params(ws)} result] } {
|         puts "XSCTHELPER IN..."
|     (file "/home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/plnx_aarch64-xilinx-linux/pmu-firmware/2017.1+gitAUTOINC+3813f14966-r0/app.tc..." line 120)
| WARNING: /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/plnx_aarch64-xilinx-linux/pmu-firmware/2017.1+gitAUTOINC+3813f14966-r0/temp/run.do_configure.24899:1 exit 1 from 'eval xsct /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/plnx_aarch64-xilinx-linux/pmu-firmware/2017.1+gitAUTOINC+3813f14966-r0/app.tcl -ws /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/../components/plnx_workspace -pname pmu-firmware -rp /opt/pkg/tools/hsm/data/embeddedsw -processor psu_pmu_0 -hdf /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/deploy/images/plnx_aarch64/Xilinx-plnx_aarch64.hdf -arch 32 ${APP_ARG} ${MISC_ARG}'
| ERROR: Function failed: do_configure (log file is located at /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/plnx_aarch64-xilinx-linux/pmu-firmware/2017.1+gitAUTOINC+3813f14966-r0/temp/log.do_configure.24899)
Re: build error in sdk 2017.1
Hi @jenny_august13,
Could you check your proxy settings in the SDK preferences (Window > Preferences).
 In General > Network, Change Active provider to Direct
If it doesn't help, could you share the log file mentioned:
Thanks and Regards,
Florent
Florent
Hi florentw, i am using petalinux tools on my linux system and i am not using through sdk... Do I need sdk 2017 to be installed for this?
Hi @jenny_august13,
No... I have sent you this because the title of your issue is SDK 2017.1 not petalinux...
Then could you share the log file mentioned?
Florent
Florent
I can find only SDK.log at that path and i cannot find the path to above log file.. and it is not buiding with the following errors which has perfectly worked with petalinux 2015.4 but now it is giving compiling error.
Parsing of 2449 .bb files complete (2414 cached, 35 parsed). 3239 targets, 224 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:10Checking sstate mirror object availability: 100% |###############| Time: 0:00:12NOTE: Executing SetScene Tasks ETA: 0:00:01
NOTE: Executing RunQueue Tasks
ERROR: multiUDP-1.0-r0 do_compile: oe_runmake failed
ERROR: multiUDP-1.0-r0 do_compile: Function failed: do_compile (log file is located at /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/aarch64-xilinx-linux/multiUDP/1.0-r0/temp/log.do_compile.30881)
ERROR: Logfile of failure stored in: /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/aarch64-xilinx-linux/multiUDP/1.0-r0/temp/log.do_compile.30881
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 4
| ERROR: oe_runmake failed
| aarch64-xilinx-linux-gcc --sysroot=/home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/sysroots/plnx_aarch64 -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/aarch64-xilinx-linux/multiUDP/1.0-r0=/usr/src/debug/multiUDP/1.0-r0 -fdebug-prefix-map=/home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/sysroots/plnx_aarch64= -c -o multiUDP.o multiUDP.c
| multiUDP.c:42:26: fatal error: multiUDPecho.h: No such file or directory
| #include "multiUDPecho.h"
| compilation terminated.
| make: *** [<builtin>: multiUDP.o] Error 1
| ERROR: Function failed: do_compile (log file is located at /home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/build/tmp/work/aarch64-xilinx-linux/multiUDP/1.0-r0/temp/log.do_compile.30881)
ERROR: Task (/home/janani/projects/peta2017.1-zcu102/zcu102/pet_zcu102/project-spec/meta-user/recipes-apps/multiUDP/multiUDP.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2453 tasks of which 2447 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Hi @jenny_august13,
Did you created a new petalinux project when moving from 2015.4 to 2017.1?
Is your hdf file coming from 2017.1?
Florent
Florent
The procedure I am following is got my hdf file in windows machine and imported it into my petalinux project copying that file into my linux machine. If petalinux 2016.4 is being used does it take 2017.1 hdf file? or how can I check the configuration of petalinux tool in the linux system?
And the root fs app which is not building is having pthread in it and i changed the make file adding -pthread command at the end of my compilation line how i did when i am using 2015.4 petalinux and built the project successfully that time.
When i disabled the application that has pthreads in the rootfs , and built the project and it has showed the following warnings
petalinux-user-image-1.0-r0 do_rootfs: The postinstall intercept hook 'update_font_cache' failed (exit code: 1)! See log for details!
WARNING: petalinux-user-image-1.0-r0 do_rootfs: The postinstall intercept hook 'update_pixbuf_cache' failed (exit code: 1)! See log for details!
WARNING: petalinux-user-image-1.0-r0 do_rootfs: The postinstall intercept hook 'update_icon_cache' failed (exit code: 1)! See log for details!
WARNING: petalinux-user-image-1.0-r0 do_rootfs: The postinstall intercept hook 'update_gio_module_cache' failed (exit code: 1)! See log for details!
WARNING: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 4 warning messages in the logfile:
[log_check] WARNING: The postinstall intercept hook 'update_font_cache' failed (exit code: 1)! See log for details!
[log_check] WARNING: The postinstall intercept hook 'update_pixbuf_cache' failed (exit code: 1)! See log for details!
[log_check] WARNING: The postinstall intercept hook 'update_icon_cache' failed (exit code: 1)! See log for details!
[log_check] WARNING: The postinstall intercept hook 'update_gio_module_cache' failed (exit code: 1)! See log for details!
Visitor martindreher
here is the solution for the timeout error. But I think you will then get then next error ...
https://forums.xilinx.com/t5/Embedded-Development-Tools/Xilinx-2016-4-xsct-Timeout-while-building-fsbl-and-pmu-firmware/td-p/766876
In fsbl and pmufw recipes add this the line
export _JAVA_OPTIONS = "-Duser.home=${TMPDIR}/xsctenv"
