Visitor yjp1983
can not compile with the mmu
I'm a newer to Xilinx, and I port petalinux to fpga board.
I had port petalinux without(petalinux-v0.30-rc1.tar.gz ) mmu to board success,
 but i can't compile success when use this code(petalinux-mmu-v0.10.tar.gz),
the error is :
make all
make -C tools/ucfront
make[1]: Entering directory `/home/jinpeng/petalogix/petalinux-mmu-v0.10/software/petalinux-dist/tools/ucfront'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/jinpeng/petalogix/petalinux-mmu-v0.10/software/petalinux-dist/tools/ucfront'
ln -sf /home/jinpeng/petalogix/petalinux-mmu-v0.10/software/petalinux-dist/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /home/jinpeng/petalogix/petalinux-mmu-v0.10/software/petalinux-dist/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /home/jinpeng/petalogix/petalinux-mmu-v0.10/software/petalinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld
make ARCH=microblaze CROSS_COMPILE=mb-linux- -j4 -C linux-2.6.x  || exit 1
/bin/sh: line 1: 26071 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mcpu=v7.10.d -S -o /dev/null -xc /dev/null >/dev/null 2>&1
/bin/sh: line 1: 26074 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mno-xl-soft-mul -ffixed-r31 -fomit-frame-pointer -fno-stack-protector -S -o /dev/null -xc /dev/null >/dev/null 2>&1
/bin/sh: line 1: 26077 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mno-xl-soft-mul -ffixed-r31 -fomit-frame-pointer -Wdeclaration-after-statement -S -o /dev/null -xc /dev/null >/dev/null 2>&1
/bin/sh: line 1: 26079 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mno-xl-soft-mul -ffixed-r31 -fomit-frame-pointer -Wno-pointer-sign -S -o /dev/null -xc /dev/null >/dev/null 2>&1
make[1]: Entering directory `/home/jinpeng/petalogix/petalinux-mmu-v0.10/software/linux-2.6.x-petalogix'
/bin/sh: line 1: 26102 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -mcpu=v7.10.d -S -o /dev/null -xc /dev/null >/dev/null 2>&1
scripts/kconfig/conf -s arch/microblaze/Kconfig
.config:426:warning: symbol value '2.5' invalid for XILINX_MPMC_0_MEM_PART_CAS_B
.config:892:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_1_VALUE
.config:893:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_2_VALUE
.config:894:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_3_VALUE
.config:895:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_4_VALUE
.config:896:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_5_VALUE
.config:897:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_6_VALUE
.config:898:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_7_VALUE
# configuration written to .config
include/config/auto.conf:764:warning: symbol value '2.5' invalid for XILINX_MPMC_0_MEM_PART_CAS_B
include/config/auto.conf:1031:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_1_VALUE
include/config/auto.conf:1036:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_2_VALUE
include/config/auto.conf:1044:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_3_VALUE
include/config/auto.conf:1051:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_4_VALUE
include/config/auto.conf:1056:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_5_VALUE
include/config/auto.conf:1064:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_6_VALUE
include/config/auto.conf:1071:warning: symbol value '0x001' invalid for XILINX_MPMC_0_SKIP_7_VALUE
make[1]: Leaving directory `/home/jinpeng/petalogix/petalinux-mmu-v0.10/software/linux-2.6.x-petalogix'
/bin/sh: line 1: 26162 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mcpu=v7.10.d -S -o /dev/null -xc /dev/null >/dev/null 2>&1
/bin/sh: line 1: 26165 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mno-xl-soft-mul -ffixed-r31 -fomit-frame-pointer -fno-stack-protector -S -o /dev/null -xc /dev/null >/dev/null 2>&1
/bin/sh: line 1: 26168 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mno-xl-soft-mul -ffixed-r31 -fomit-frame-pointer -Wdeclaration-after-statement -S -o /dev/null -xc /dev/null >/dev/null 2>&1
/bin/sh: line 1: 26170 Floating point exceptionmb-linux-gcc -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mno-xl-soft-mul -ffixed-r31 -fomit-frame-pointer -Wno-pointer-sign -S -o /dev/null -xc /dev/null >/dev/null 2>&1
  CHK     include/linux/version.h
  CHK     include/linux/utsrelease.h
  CC      scripts/mod/empty.o
/bin/sh: line 1: 26281 Floating point exceptionmb-linux-gcc -Wp,-MD,scripts/mod/.empty.o.d -nostdinc -isystem -D__KERNEL__ -Iinclude -include include/linux/autoconf.h -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -mno-xl-soft-mul -ffixed-r31 -fomit-frame-pointer -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(empty)" -D"KBUILD_MODNAME=KBUILD_STR(empty)" -c -o scripts/mod/empty.o scripts/mod/empty.c
make[3]: *** [scripts/mod/empty.o] Error 136
make[2]: *** [scripts/mod] Error 2
make[1]: *** [scripts] Error 2
make: *** [linux] Error 1
I had seared on the net, but not get useful infomation, My god !!!
who can give me some suggestion?
best wishes!!!
Message Edited by yjp1983 on 05-12-2009 12:29 AM
Visitor yjp1983
Re: can not compile with the mmu
when i use mb-linux-gcc, the following output:
 mb-linux-gcc -o main.o -c main.c
and if i use microblaze-uclinux-gcc, it work ok,
Maybe I forgot something to set???
None of our work on Microblaze with MMU and Linux from Xilinx is released to the public yet as we're still working on it.
You may need to go to the Petalogix mailing list for any support.  This work is still in progress so you need to understand you're not working with a production kernel and many things are still changing.
Sorry,
John
Visitor yjp1983
ok! i know! thanks.
