Scholar trenz-al
can not install petalinux 2015.4
we had very little problems with petalinux releases until 2015.4
2015.4 just does not even install anymore...! What is happening?
/root/Downloads/petalinux-v2015.4-final-installer.run: line 131: /tmp/tmp.Cjtx97G1pV/petalinux-v2015.4-final/tools/common/petalinux/utils/petalinux-install: cannot execute binary file
and yes I have read the petalinux install guide, there is however only guide for 2014.2 version no newer version can be found.
Re: can not install petalinux 2015.4
This error occurs when the Virtual machine is a 32-bit OS.
Petalinux only supports 64-bit hosts.
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
Scholar trenz-al
maybe it would be wise to write this in PETALINUX INSTALL DOCUMENT ??
2015.2 did work in 32 bit...
