Visitor tristalee
can't boot linux with HDMI output on zedboard from sd card
Hi, everyone!
I'm trying to boot zedboard from sd card and I built the boot image myself following the steps on:
https://wiki.analog.com/resources/tools-software/linux-drivers/platforms/zynq
The HDL design I used to export to the SDK is :
https://github.com/analogdevicesinc/hdl/tree/master/projects/adv7511/zed
The block design is shown in the attachment.
This design can run sucessfully with its no-OS software, however, it doesn't work when I used it to generate boot image. I was wondering that if this hdl design can be used in sd boot. If not, should I need to disable QUAD SPI?
Thanks a lot!
Tags (2)
