luluzhang
cannot write to /opt/Xilinx, check the read/write permissions
My Ubuntu version is: 16.04.
I run the following commands:
ardeal@ubuntu:~/xilinux$ mkdir -p /opt/pkg/petalinux/
ardeal@ubuntu:~/xilinux$ chmod 755 Xilinx_SDK_2018.2_0614_1954_Lin64.bin
ardeal@ubuntu:~/xilinux$ chmod 755 /opt/pkg/petalinux
ardeal@ubuntu:~/xilinux$ ./Xilinx_SDK_2018.2_0614_1954_Lin64.bin /opt/pkg/petalinux/
I got the following issue:
I search the issue on Google, and found the following page:
https://forums.xilinx.com/t5/Installation-and-Licensing/Installing-Vivado-2017-2-on-Ubuntu-16-04-1-LTS-VMware-Fusion/td-p/788306
This is the same issue as mine. its solution didn't fixed my issue.
Do you have any suggestion for my issue?
Many thanks and Best Regards,
Ardeal
shabbirk
Hi Adreal
Set the user permission to /opt/pkg/petalinux using chown command
Try running ls -l /opt/pkg/petalinux and if it is set to root, you will need to change to username using sudo chown -R username:username /opt/pkg/petalinux
Best Regards
Shabbir
shabbirk
Hi Adreal
Best Regards
Shabbir
luluzhang
Hi Moderator,
Many thanks for your answer!
You answer did work!
My issue is fixed!
Thanks again!
