vishu26
changing the bootargs by editing system-user.dtsi file
I am using petalinux 2020.2 and the goal is to add a device IP as uio. I have followed from some posts that I need to add the following lines in system-user.dtsi file:
/include/ "system-conf.dtsi"
    chosen{
    bootargs = "console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio";
The file is located in <plnx-project>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi. After doing the changes I run
petalinux-build
To confirm if the bootargs have changed I run
petalinux-config
I go to DTG Settings -> Kernel Bootargs  and I see following:
I see the bootargs have not changed. Did I miss something here?
Thanks and Regards
Vishav
vishu26
So I flashed the image and saw that the bootargs are in effect. However, they are not changed in petalinux config files. I suspect that the bootargs get stored in dtb and are overwritten at kernel boot.
Vishav
vishu26
Vishav
