clocks in device tree
for clocks in the device tree, does the first number correspond to the clkc node?
So, for this
clocks = <0x2 16>;
what is the 0x2? The second number is the actual clock correct? So, fclk1 in my case?
http://lxr.free-electrons.com/source/Documentation/devicetree/bindings/clock/zynq-7000.txt
I'm using the device tree that is provided with the meta-xilinx layer and when I add a label and try to reference it I just get a parse error when the dtc goes through it.
This is my current clkc...not sure how to properly add the clkc label and reference it.
ps7-slcr@f8000000 {
#address-cells = <0x1>;
#size-cells = <0x1>;
compatible = "xlnx,zynq-slcr", "syscon", "xlnx,ps7-slcr-1.00.a";
ranges;
reg = <0xf8000000 0x1000>;
clkc@100 {
#clock-cells = <0x1>;
clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x", "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x", "dci", "lqspi", "smc", "pcap", "gem0", "gem1", "fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1", "sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1", "dma", "usb0_aper", "usb1_aper", "gem0_aper", "gem1_aper", "sdio0_aper", "sdio1_aper", "spi0_aper", "spi1_aper", "can0_aper", "can1_aper", "i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper", "gpio_aper", "lqspi_aper", "smc_aper", "swdt", "dbg_trc", "dbg_apb";
compatible = "xlnx,ps7-clkc";
fclk-enable = <0xf>;
ps-clk-frequency = <0x1fca055>;
reg = <0x100 0x100>;
linux,phandle = <0x2>;
phandle = <0x2>;
Re: clocks in device tree
You don't have any labels in that snippet. The syntax is
[<label>:] <node_name> {
Then you can reference that node with
&<label>
&<label>
