Anonymous
Not applicable
compilation error for can4linux 4.2
I tried to compile the latest version of can4linux driver i.e. version 4.2 and I get errors!! The sources are compiled against kernel version 3.6
The cross-zedboard file is attached. Can someone help out to fix it?
root@PC:/home/naiad/tmp/can4linux_svn273/can4linux# make TARGET=ZEDBOARD
CURDIR = /home/naiad/tmp/can4linux_svn273/can4linux
CC = /opt/Xilinx/14.7/ISE_DS/EDK/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc
test ! -d /home/naiad/tmp/linux-xlnx-xilinx-v14.4 || make -C /home/naiad/tmp/linux-xlnx-xilinx-v14.4 M=/home/naiad/tmp/can4linux_svn273/can4linux TARGET=ZEDBOARD modules
make[1]: Entering directory `/home/naiad/tmp/linux-xlnx-xilinx-v14.4'
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/core.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/open.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/read.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/write.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/ioctl.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/select.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/debug.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/util.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/sysctl.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/async.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/close.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/xcanpsfuncs.o
CC [M] /home/naiad/tmp/can4linux_svn273/can4linux/zedboard.o
/home/naiad/tmp/can4linux_svn273/can4linux/zedboard.c: In function 'xcan_probe':
/home/naiad/tmp/can4linux_svn273/can4linux/zedboard.c:65:5: error: 'struct platform_device' has no member named 'id_auto'
/home/naiad/tmp/can4linux_svn273/can4linux/zedboard.c:48:16: warning: unused variable 'dev' [-Wunused-variable]
/home/naiad/tmp/can4linux_svn273/can4linux/zedboard.c: At top level:
/home/naiad/tmp/can4linux_svn273/can4linux/zedboard.c:194:13: warning: 'print_device_tree_node' defined but not used [-Wunused-function]
make[2]: *** [/home/naiad/tmp/can4linux_svn273/can4linux/zedboard.o] Error 1
make[1]: *** [_module_/home/naiad/tmp/can4linux_svn273/can4linux] Error 2
make[1]: Leaving directory `/home/naiad/tmp/linux-xlnx-xilinx-v14.4'
make: *** [all] Error 2
You're building against an older linux version. It is possible to fix, but the simper path is to either upgrade your linux, or use a slightly older version of can4linux. For example, it builds fine against linux 3.9.
Anonymous
Not applicable
Thank you!! It worked with can4linux version 4.1
Great!
If you are using extended frames (CAN 2.0B) then there is a bugfix you'll want to include: http://sourceforge.net/p/can4linux/code/273 otherwise you may find some CAN transfers mysteriously don't work.
