compilation issues of logiCore video mixer v2.0 driver for linux
I am trying to compile logicore video mixer v2.0 driver for linux kernel. Accordingly
1)I have cloned following github repo
https://github.com/Xilinx/linux-xlnx.git
2)I have checked out branch 2017.3_video_ea
during compilation I have faced with an issue. whereby linking with math functions like __udivi3 is failing.
My Hardware platform is zynq7035 (armv7-a based dual core processor)
I am using gcc cross compiler  from linaro version is    gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) .
The detailed compilation logs are as attached below-:
arm-linux-gnueabihf-ld -EL -p --no-undefined -X --pic-veneer --build-id -o .tmp_vmlinux1 -T ./arch/arm/kernel/vmlinux.lds arch/arm/kernel/head.o init/built-in.o --start-group usr/built-in.o arch/arm/kernel/built-in.o arch/arm/mm/built-in.o arch/arm/common/built-in.o arch/arm/probes/built-in.o arch/arm/net/built-in.o arch/arm/crypto/built-in.o arch/arm/firmware/built-in.o kernel/built-in.o certs/built-in.o mm/built-in.o fs/built-in.o ipc/built-in.o security/built-in.o crypto/built-in.o block/built-in.o arch/arm/lib/lib.a lib/lib.a arch/arm/lib/built-in.o lib/built-in.o drivers/built-in.o sound/built-in.o firmware/built-in.o net/built-in.o virt/built-in.o --end-group
drivers/built-in.o: In function `Si5324_RatApprox':
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:45: undefined reference to `__udivdi3'
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:52: undefined reference to `__umoddi3'
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:56: undefined reference to `__udivdi3'
drivers/built-in.o: In function `Si5324_FindN2ls':
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:95: undefined reference to `__udivdi3'
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:124: undefined reference to `__udivdi3'
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:126: undefined reference to `__udivdi3'
drivers/built-in.o:/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:189: more undefined references to `__udivdi3' follow
drivers/built-in.o: In function `Si5324_CalcFreqSettings':
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:312: undefined reference to `__divdi3'
/home/prashant/development/logic_core_graphics/linux-xlnx/drivers/staging/xilinx/clk/si5324drv.c:316: undefined reference to `__divdi3'
Re: compilation issues of logiCore video mixer v2.0 driver for linux
Hi Prashanth
Can you try on 2018.1 branch (git checkout remotes/origin/xlnx_rebase_v4.14) where the mixer driver has been pushed into the kernel of this version
I have tried at our end and didnt see any errors with 2018.1 branch
Best Regards
Shabbir
I kind of made it work , replacing the those mod/div functions from linux legacy code.
