Observer a70024
compile error - can't find system-top.dtsi
Dear XLINIX:
  I was  DM1 example with petalinux-build command, and run into a compile error, it seams can't find system-top.dts.
could you help me to deal with this error?
My petalinux is installed by petalinux-v2017.4-final-installer.run. and here is all build command I used.
cd $TRD_HOME/apu/petalinux_bsp
petalinux-config --oldconfig
cd project-spec/meta-user/recipes-bsp/device-tree/files/
cp zcu102-base-dm1.dtsi system-user.dtsi
petalinux-build
DEBUG: Executing shell function do_compile
gcc: error: /home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/../components/plnx_workspace/device-tree/device-tree-generation/system-top.dts: No such file or directory
gcc: warning: ‘-x assembler-with-cpp’ after last input file has no effect
gcc: fatal error: no input files
compilation terminated.
WARNING: /home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/run.do_compile.9937:1 exit 1 from 'gcc -E -nostdinc -Ulinux -I/home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0 -I/home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/../components/plnx_workspace/device-tree/device-tree-generation -I/home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work-shared/plnx_aarch64/kernel-source/include -x assembler-with-cpp -o /home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/../components/plnx_workspace/device-tree/device-tree-generation/plnx_aarch64-system.pp /home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/../components/plnx_workspace/device-tree/device-tree-generation/system-top.dts'
ERROR: Function failed: do_compile (log file is located at /home/lucas/Project/ZCU102/source/TRD_HOME/rdf0429-zcu102-es2-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_compile.9937)
Best regards
Lucas liu
Re: compile error - can't find system-top.dtsi
Hi @a70024,
PetaLinux 2016.4 onwards is yocto backend so you don't see the kernel source under components directory like older petalinux tools.
Refer UG1144 for more details.
Sandeep
Hi Lucas,
Looks like you are using the 2017-1 bsp with your 2017-4 installation. Please use the 2017-4 bsp which you can download here, under Petalinux-2017.4 Installation Files.
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
Observer a70024
Dear Xinlinx:
  after following your guide, I can build petalinux correctly. thanks a lot.
But I don't see kernel code exist under the component/ folder.
If I have a requirement to customized kernel code, do I need to download petalinux-v2017.1-open_source_components.tar.gz from official site and decompress it under component/ by myself?
If I do so, is petalinux-build flow able to build the installed kernel code automatically?
Best Regards
Lucas
Hi @a70024,
Sandeep
