maikonnascimento
compile module : invalid module format
I am trying a simple thing , compiling a module.
where I downloaded : linux-xlnx-xlnx_rebase_v4.14_2018.2
my makefile to compile the module is :
export ARCH:=arm
export CROSS_COMPILE:=arm-xilinx-linux-gnueabi-
CC=$(CROSS_COMPILE)gcc
obj-m += luscher.o
KDIR  := /home/maikon/Downloads/linux-xlnx-xlnx_rebase_v4.14_2018.2
PWD        := $(shell pwd)
default:
    ${MAKE} -C ${KDIR} -I ${KDIR}/include -I. M=${PWD} modules
clean:
    rm -rf *.o *.mod.* *.symvers *.order *~ *.cmd .tmp*
in the directory : linux-xlnx-xlnx_rebase_v4.14_2018.2 , which is the same the makefile is pointing I run:
make ARCH=arm xilinx_zynq_defconfig
make ARCH=arm modules
but I tried other commands like :
source ~/x/Vivado/2018.2/settings64.sh
cp ./arch/arm/configs/xilinx_zynq_defconfig .config
make ARCH=arm prepare
my board has a kernel : Linux peta64v2 4.14.0-xilinx-v2018.2 #2 SMP PREEMPT Fri Feb 8 09:34:20 PST 2019 armv7l GNU/Linux
when I run file my module I get:
file luscher.ko
luscher.ko: ELF 32-bit LSB relocatable, ARM, EABI5 version 1 (SYSV), BuildID[sha1]=11b866e74481f70b1fc274305ddd5171756a748c, not stripped
Tags (3)
maikonnascimento
tks for replying , I feel a bit embarassed .. I just followed :
how to compile the module in a cross compiling way
https://github.com/SDU-Embedded/linux_zynq/wiki/Installing-Linux-on-the-ZYBO
https://github.com/SDU-Embedded/linux_zynq/wiki/Cross-Compiling-Kernel-Modules-for-the-Zynq-7000-Series-Platform
apt install libncurses5-dev libncursesw5-dev u-boot-tools device-tree-compiler flex libssl-dev
export CROSS_COMPILE=arm-xilinx-linux-gnueabi-
source <Xilinx installation directory>/Vivado/<version>/settings64.sh
in the download kernel free downloaded:
make ARCH=arm menuconfig
make ARCH=arm UIMAGE_LOADADDR=0x8000 uImage
then the makefile of the module is :
export ARCH:=arm
obj-m += simple.o
KDIR  := path/to/linux-xlnx-zynmp-dt-fixes-for-4.10
PWD        := $(shell pwd)
default:
    ${MAKE} -C ${KDIR} M=${PWD} modules
clean:
    ${MAKE} -C ${KDIR} M=${PWD} clean
hokim
Could you show the result of the following command?
$ modinfo luscher.ko
maikonnascimento
export ARCH:=arm
obj-m += simple.o
PWD        := $(shell pwd)
default:
clean:
