04-23-2015 10:42 AM
When I follow the steps to rebuikl the qt from sources in
http://www.wiki.xilinx.com/Zynq+Qt+and+Qwt+Base+Libraries-Build+Instructions
I get the following output when running the configure command
gsanson@ubuntu12:/opt/pkg/Qt/build/qt-everywhere-opensource-src-4.8.5$ ./configure -embedded arm -xplatform qws/linux-arm-gnueabi-g++ -little-endian -opensource -host-little-endian -confirm-license -nomake demos -nomake examples -prefix $ZYNQ_QT_INSTALL
This is the Qt for Embedded Linux Open Source Edition.
You are licensed to use this software under the terms of
the Lesser GNU General Public License (LGPL) versions 2.1.
You are also licensed to use this software under the terms of
the GNU General Public License (GPL) versions 3.
You have already accepted the terms of the license.
Creating qmake. Please wait...
g++ -c -o project.o -pipe -m64 -DQMAKE_OPENSOURCE_EDITION -g -I. -Igenerators -Igenerators/unix -Igenerators/win32 -Igenerators/mac -Igenerators/symbian -Igenerators/integrity -I/opt/pkg/Qt/build/qt-everywhere-opensource-src-4.8.5/include -I/opt/pkg/Qt/build/qt-everywhere-opensource-src-4.8.5/include/QtCore -I/opt/pkg/Qt/build/qt-everywhere-opensource-src-4.8.5/src/corelib/global -I/opt/pkg/Qt/build/qt-everywhere-opensource-src-4.8.5/src/corelib/xml -I/opt/pkg/Qt/build/qt-everywhere-opensource-src-4.8.5/tools/shared -DQT_NO_PCRE -DQT_BUILD_QMAKE -DQT_BOOTSTRAPPED -DQLIBRARYINFO_EPOCROOT -DQT_NO_TEXTCODEC -DQT_NO_UNICODETABLES -DQT_NO_COMPONENT -DQT_NO_STL -DQT_NO_COMPRESS -I/opt/pkg/Qt/build/qt-everywhere-opensource-src-4.8.5/mkspecs/qws/linux-x86_64-g++ -DHAVE_QCONFIG_CPP -DQT_NO_THREAD -DQT_NO_QOBJECT -DQT_NO_GEOM_VARIANT -DQT_NO_DEPRECATED project.cpp
g++: error: unrecognized command line option '-m64'
make: *** [project.o] Error 1
Does anyone know what is happening and why? I get that this may be a 32/64 bit issue.
Dev Platform
Ubuntu 12.04 LTS 64bit
Gary
04-23-2015 09:56 PM
04-24-2015 10:13 AM
Thanks for the response
Yes I have doen that that set but that is what is confusing. I've got everything set as suggested or how I thought they should be based upon the AR
Here is the list of installed cros compilers under the /opt directory
./pkg/petalinux-v2014.4-final/tools/linux-i386/arm-xilinx-gnueabi
./pkg/petalinux-v2014.4-final/tools/linux-i386/arm-xilinx-linux-gnueabi
./pkg/petalinux-v2014.4-final/tools/linux-i386/arm-xilinx-linux-gnueabi/arm-xilinx-linux-gnueabi
./pkg/petalinux-v2014.4-final/tools/linux-i386/arm-xilinx-linux-gnueabi/arm-xilinx-linux-gnueabi/include/c++/4.8.3/arm-xilinx-linux-gnueabi
./pkg/petalinux-v2014.4-final/tools/linux-i386/arm-xilinx-linux-gnueabi/lib/gcc/arm-xilinx-linux-gnueabi
./pkg/petalinux-v2014.4-final/tools/linux-i386/arm-xilinx-linux-gnueabi/libexec/gcc/arm-xilinx-linux-gnueabi
./Xilinx/SDK/2014.4/gnu/arm/lin/arm-xilinx-linux-gnueabi
./Xilinx/SDK/2014.4/gnu/arm/lin/arm-xilinx-linux-gnueabi/include/c++/4.8.3/arm-xilinx-linux-gnueabi
./Xilinx/SDK/2014.4/gnu/arm/lin/lib/gcc/arm-xilinx-linux-gnueabi
./Xilinx/SDK/2014.4/gnu/arm/lin/share/doc/xilinx-arm-xilinx-linux-gnueabi
./Xilinx/SDK/2014.4/gnu/arm/lin/libexec/gcc/arm-xilinx-linux-gnueabi
./Xilinx/SDK/2014.4/gnu/arm/lin/i686-pc-linux-gnu/arm-xilinx-linux-gnueabi
Which one should be used?
And my envronment variable
CROSS_COMPILE=arm-xilinx-linux-gnueabi-
ARCH=arm
PETALINUX=/opt/pkg/petalinux-v2014.4-final
PATH=/opt/Xilinx/SDK/2014.4/gnu/arm/lin/arm-xilinx-linux-gnueabi/bin:/opt/Xilinx/SDK/2014.4/bin:/opt/Xilinx/Vivado/2014.4/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/opt/Xilinx/Vivado/2014.4/bin:/opt/Xilinx/SDK/2014.4/bin
PETALINUX_VER=2014.4
ZYNQ_TRD_HOME=/opt/pkg/rdf0286-zc702-zvik-base-trd-2014-4
ZYNQ_QT_BUILD=/opt/pkg/Qt/build
ZYNQ_QT_INSTALL=/opt/pkg/Qt/install
Any other ideas?
Gary
04-27-2015 02:45 AM
We can set crosscompiler path to either XSDK or Petalinux.
Looking in gcc documentation option "-m64" generates code for a 32-bit or 64-bit environment.
Simply check if option (-m64) is supported on host compiler.
<cross-compiler>-g++ -m64 hello.cpp
<cross-compiler>-g++ -m32 hello.cpp
-Radhey
04-27-2015 03:02 AM - edited 04-27-2015 03:04 AM
To add:
Here is my G++ configuration.
linux-xlnx]$ g++ -v
Using built-in specs.
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --disable-plugin --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=x86_64-redhat-linux
Thread model: posix
gcc version 4.1.2 20080704 (Red Hat 4.1.2-54)
