couldn't find phy i/f : Linux on microblaze [VC707]
Hi, everyone! I'm trying to use 10G ethernet on Linux[petalinux 2018.3] with my VC707 board. My Block Design is in the Tcl script attached to this post and my devicetree is bellow :
/include/ "system-conf.dtsi"
&axi_10g_ethernet_0 {
    mdio {
        phy0: phy@7 {
            device_type = "ethernet-phy";
            reg = <7>;
Re: couldn't find phy i/f : Linux on microblaze [VC707]
Yes, the error message is: couldn't find phy i/f.
When the system boots, running "ifconfig" the eth0 interface is detected but no ip is assigned to it.
Can you check your clock ref? Is this correct?
I'm generating a 156.25 Mhz Square Wave and using it as a clock reference. I'm putting this signal on the following FPGA pins :
  • SMA_MGT_REFCLK_N
  • SMA_MGT_REFCLK_P
In the constraints file I'm doing :
set_property PACKAGE_PIN AK7 [get_ports SMA_MGT_REFCLK_N]
set_property PACKAGE_PIN AK8 [get_ports SMA_MGT_REFCLK_P]
The generated signal has the following definitions :
  • Frequency = 156.25 Mhz
  • Amplitude = 160mV
The signals are insterted into the board by SMA cables
