Observer avnetwatson
cpu clock freq change
I found the following message during linux boot up and running linaro ubuntu.
cpufreq_cpu0: failed to set clock rate: -16
cpufreq: __cpufreq_driver_target: Failed to change cpu frequency: -16
The system can still work but the above messages appear periodically.
What's wrong?
I'm using xilinx kernel @tag version xilinx-2014.2
watson
Scholar milosoftware
Re: cpu clock freq change
Current kernel reports to be able to switch to 222 MHz, but when ask to do so, it errors. The 333 and 666 settings work fine.
This is related to the change to allow only multiple-of-2 dividers which apparently doesn't filter out the unsupported ones to the governor. The governor then tries to switch to frequencies that do not work.
Is this a kernel issue ?
Visitor asigint
To get rid of the message, I made the following change to my device tree:
In the section: ps7_cortexa9_0: cpu@0 {}
change from:
operating-points = <666667 1000000 333334 1000000 222223 1000000>;
to:
operating-points = <666667 1000000 333334 1000000>;
This doesn't really fix anything, other than to stop trying to use 222MHz which doesn't seem to work. If anyone knows how to fix it please share.
Also, it seems you should be able to set the frequency with a command like:
echo 666667 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
but that doesn't work for me. I get
echo: write error: Invalid argument
Not sure if this is related.
Jerry
What governor are you using? I suspect anything else, but not 'userspace'. Hence, no userspace control over the frequency.
Visitor vibishna
I know this is a very old post. But I thought it is worth discussing.
This problem started popping up, once I started playing with the governor in menu config. I can get rid of this problem using the following command instantaneously:
"sudo cpufreq-set -g userspace"
I made a script to run this command on boot up. But that did not work. I have to issue the above command only after this error gets displayed.
