cross compile linux application but wrong includes?
Hi there,
I've got a Zynq device (MYIR 7020) at my desk and it's running Ubuntu 12.04. I'm able to ssh -X connect to that board and show GUI applications on my host machine.
For debug reasons I would like to implement a GUI application with the JUCE framework and cross compile it for the Zynq. The makefile is created and I manipulated it to suppress compiler warnings.
This is my first compiler output.
$ CXX=arm-linux-gnueabihf-g++ TARGET_ARCH= CXXFLAGS=-D__STRICT_ANSI__ V=1 make
In file included from /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/libc/usr/include/wchar.h:30:0, from /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/include/c++/7.2.1/cwchar:44, from /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/include/c++/7.2.1/bits/postypes.h:40, from /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/include/c++/7.2.1/iosfwd:40, from /opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/include/c++/7.2.1/memory:72, from /usr/CrossCompile/JUCE/modules/juce_core/system/juce_StandardHeader.h:46, from /usr/CrossCompile/JUCE/modules/juce_core/juce_core.h:201, from ../../Source/../JuceLibraryCode/JuceHeader.h:17, from ../../Source/Main.cpp:11: /usr/include/x86_64-linux-gnu/bits/floatn.h:75:70: error: unknown machine mode ‘__TC__’ typedef _Complex float __cfloat128 __attribute__ ((__mode__ (__TC__)));
I've noticed there are some suspicious include paths in the complete make call.
-I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/x86_64-linux-gnu
The bits/floatn.h file is not present in my Xilinx toolchain. My path variable is attached.
How can I prepare the freetype2, libpng16 packages for the Zynq and how can I make sure the floatn.h is present?
Cheers
Thomas
Voyager
Voyager
Re: cross compile linux application but wrong includes?
Have you source your SDK env ?
Cheers,
Trigger
Yes. It's in the path.txt
