customer's board zc045, network works ok in u-boot ,but not in linux . can anyone help?
the board'network works well. ping and tftp are both ok. however , it doesnt work in linux. the message is below.
root@zynq7045_net:~# ifconfig eth0 172.17.254.247
root@zynq7045_net:~# ping 172.17.252.244
PING 172.17.252.244 (172.17.252.244): 56 data bytes
^C
--- 172.17.252.244 ping statistics ---
11 packets transmitted, 0 packets received, 100% packet loss
eth0 Link encap:Ethernet HWaddr 00:0A:35:00:1E:53
inet addr:172.17.254.247 Bcast:172.17.255.255 Mask:255.255.0.0
UP BROADCAST RUNNING MULTICAST MTW:1500 Metric:1
RX packets:0 errors:1905 dropped:0 overruns:0 frame:1905
TX packets:28 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:6720 (6.5 KiB)
Interrupt:28 Base address:0xb000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:11 errors:0 dropped:0 overruns:0 frame:0
TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1232 (1.2 KiB) TX bytes:1232 (1.2 KiB)
the ethtool 's message is below:
root@xilinx-zc706-2018_1:/run/media/mmcblk0p1# ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 7
Transceiver: internal
Auto-negotiation: on
Link detected: yes
root@xilinx-zc706-2018_1:/run/media/mmcblk0p1# ethtool -i eth0
driver: macb
version:
firmware-version:
expansion-rom-version:
bus-info: e000b000.ethernet
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
root@xilinx-zc706-2018_1:/run/media/mmcblk0p1# ethtool -S eth0
NIC statistics:
tx_octets: 7862
tx_frames: 36
tx_broadcast_frames: 36
tx_multicast_frames: 0
tx_pause_frames: 0
tx_64_byte_frames: 15
tx_65_127_byte_frames: 0
tx_128_255_byte_frames: 0
tx_256_511_byte_frames: 21
tx_512_1023_byte_frames: 0
tx_1024_1518_byte_frames: 0
tx_greater_than_1518_byte_frames: 0
tx_underrun: 0
tx_single_collision_frames: 0
tx_multiple_collision_frames: 0
tx_excessive_collisions: 0
tx_late_collisions: 0
tx_deferred_frames: 0
tx_carrier_sense_errors: 0
rx_octets: 0
rx_frames: 0
rx_broadcast_frames: 0
rx_multicast_frames: 0
rx_pause_frames: 0
rx_64_byte_frames: 0
rx_65_127_byte_frames: 0
rx_128_255_byte_frames: 0
rx_256_511_byte_frames: 0
rx_512_1023_byte_frames: 0
rx_1024_1518_byte_frames: 0
rx_greater_than_1518_byte_frames: 0
rx_undersized_frames: 0
rx_oversize_frames: 0
rx_jabbers: 0
rx_frame_check_sequence_errors: 0
rx_length_field_frame_errors: 0
rx_symbol_errors: 2867
rx_alignment_errors: 2867
rx_resource_errors: 0
rx_overruns: 0
rx_ip_header_checksum_errors: 0
rx_tcp_checksum_errors: 0
rx_udp_checksum_errors: 0
root@xilinx-zc706-2018_1:/run/media/mmcblk0p1# ethtool -e eth0
Cannot get EEPROM data: Operation not supported
root@xilinx-zc706-2018_1:/run/media/mmcblk0p1# ethtool -g eth0
Ring parameters for eth0:
Pre-set maximums:
RX: 8192
RX Mini: 0
RX Jumbo: 0
TX: 4096
Current hardware settings:
RX: 512
RX Mini: 0
RX Jumbo: 0
TX: 512
since it works well in u-boot, i deduce the hardware can work well.And i can catch the boardcast packet in wiredshark , so tx is ok.
the project is created by petalinux 2018.1 . boot info is in the attachment.
what 's matter with rx ?
did anyone meet the same problem? any help is appreciate.  thanks.
boot up info:
U-Boot 2018.01 (Sep 11 2019 - 15:40:20 +0800) Xilinx Zynq ZC706
Model: Zynq ZC706 Development Board
Board: Xilinx Zynq
Silicon: v3.1
DRAM: ECC disabled 512 MiB
MMC: sdhci@e0100000: 0 (SD)
** No device specified **
Using default environment
In: serial@e0000000
Out: serial@e0000000
Err: serial@e0000000
Board: Xilinx Zynq
Silicon: v3.1
Net: ZYNQ GEM: e000b000, phyaddr 7, interface rgmii-id
eth0: ethernet@e000b000
U-BOOT for zynq7045_net
ethernet@e000b000 Waiting for PHY auto negotiation to complete.... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 172.17.253.60 (6337 ms)
reading uEnv.txt
155 bytes read in 13 ms (10.7 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
Device: sdhci@e0100000
Manufacturer ID: 9f
OEM: 5449
Tran Speed: 25000000
Rd Block Len: 512
SD version 1.0
High Capacity: Yes
Capacity: 14.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
9337552 bytes read in 796 ms (11.2 MiB/s)
Using 'conf@system-top.dtb' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x10000104
Data Size: 3296871 Bytes = 3.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: e73c85ef07064db18bb3979fc737b8c7473a5e4d
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Data Start: 0x10329898
Data Size: 6020266 Bytes = 5.7 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 3fe0267eb03323f0e65b3fb6f042320a7c664e95
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x1032506c
Data Size: 18282 Bytes = 17.9 KiB
Architecture: ARM
Hash algo: ` sha1
Hash value: bef148d91b132465035fa1c1025907844bec3741
Verifying Hash Integrity ... s衱+ OK
Booting using the fdt blob at 0x1032506c
Uncompressing Kernel Image ... OK
Loading Ramdisk to 07a42000, end 07fffcaa ... OK
Loading Device Tree to 07a3a000, end 07a41769 ... OK
Starting kernel ...
Linux version 4.14.0-xilinx-v2018.1 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP PREEMPT Wed Sep 11 15:47:33 CST 2019
CPU: PIPT / VIPT nonaliaskng data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Zynq ZC706 Development Board
earlycon: cdns0 at MMIO 0xe0000000 (options '115200n8')
bootconsole [cdns0] enabled
bootconsole [earlycon0] enabled
Memory policy: Data cache writealloc
cma: Reserved 16 MiB at 0x1f000000
cma: Reserved 16 MiB at 0?L?????j
random: fast init done
percpu: Embedded 16 pages/cpu @debc2000 s34700 r8192 d22644 u65536
Built 1 zonelists, mobility grouping on. Total pages: 130048
Kernel command line: console=ttyPS0,115200 earlycon clk_ignore_unused earlyprintk uio_pdrv_genirq.of_id=xnlx,generic-uio rootfstype=ext4 cpuidle.off=1 kernel_img=Image
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 488228K/524288K available (5120K kernel code, 209K rwdata, 1208K rodata, 1024K init, 132K bss, 19676K reserved, 16384K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0600000 (6112 kB)
.init : 0xc0800000 - 0xc0900000 (1024 kB)
.data : 0xc0900000 - 0xc0934700 ( 210 kB)
.bss : 0xc0934700 - 0xc0955764 ( 133 kB)
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
? Tasks RCU enabled.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to e0800000
slcr mapped to e0802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: D?platform modifies aux control register: 0x72360000 -> 0x72760000
L2S: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at e0802100
Zynq clock init
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at e080a000, irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
Mount-cache hash0table entries: 1024 (order??b¢??呕?
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x100000 - 0x100060
Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: thread -1, cpu 1, sock崠0, mpidr 80000001
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0840000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 27, base_baud = 6249999) is a xuartps
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 25, base_baud = 6249999) is a xuartps
?k?±??[ttyPS0] enabled
console [ttyPS0] enabled
bootconsole [cdns0] disabled
bootconsole [earlycon0] disabled
e0001000.serial: ttyPS1 at MMIO 0xe0001000 (irq = 26, base_baud = 6249999) is a xuartps
SCSI subsystem initialized
usbcore: registered new intgrface driver usbfs
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
fpga-region fpga-full: FPGA Region probed
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Freeing initrd memory: 5880K
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=17 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY) ? 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler mq-deadline registered
io scheduler kyber registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
brd: module loaded
loop: module loaded
libphy: Fixed MDIO Bus: probed
CAN device driver interface
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 28 (00:0a:35:00:1e:53)
Marvell 88E1111 e000b000.ethernet-ffffffff:07: attached PHY driver [Marvell 88E1111] (mii_bus:phy_addr=e000b000.ethernet-ffffffff:07, irq=POLL)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at e0942000 with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
failed to register cpuidle driver
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
can: controller area network core (rev 20170425 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20170425)
can: broadcast manager protocol (rev 20170425 t)
can: netlink gateway (rev 20170425) max_hops=1
hctosys: unable to open rtc device (rtc0)
of_cfs_init
mmc0: new SDHC card at address 0001
mmcblk0: mmc0:0001 SD16G 14.5 GiB (ro)
mmcblk0: p1
of_cfs_init: OK
clk: Not disabling unused clocks
Freeing unused kernel memory: 1024K
INIT: version 2.88 booting
Starting udev
udevd[612]: starting version 3.2.2
udevd[613]: starting eudev-3.2.2
mmcblk0: time2z??sending r/w cmd command, card status 0xc00900
mmcblk0: command error, retrying timeout
mmcblk0: timed out sending r/w cmd command, card status 0x800900
mmcblk0: timed out sending r/w cmd command, card status 0xc00e00
mmcblk0: timed out sending r/w cmd command, card status 0x400e00
mmc0: tried to reset card, got error -110
print_req_error: I/O error, dev mmcblk0, sector 30375808
Buffer I/O error on dev mmcblk0p1, logical block 3796720, async page read
hwclock: can't open '/dev/misc/rtc': No such file or directory
Wed Sep 11 07:49:26 UTC 2019
Starting internet superserver: inetd.
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
/etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... udhcpc (v1.24.1) started
Sending discover...
macb e000b000.ethernet eth0: link up (100/Full)
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCh8Y4nYNMZcubQ3tph5ebXkrxzslo7e8ebBx+ZR1IxxamS2HVzJN7MdiEpxcOqSdTh/eBTTAUBh9LYg6pMJ+pieDjrI1p5DTYvI+J2N4V8yYAzAsEqQkAYWchf01ZrTh86Pk8nK+vHe/q1hQcWAlHwLrAC6+JCugoTwaZWMbQD6udCzQryQ5HTKlZr95TfcjeF2F0WrX5x0Nl0fudUK6+tca7VQoCNl6kq2BRK5NUsxQ665loz/ScMDALV1lEXf0X2g1Qv2JkcykTUdnST5xmKgXpIPWlSLye0YdfqNCmUoIgkejgDwhicPjfYk2lATFIQZBYa5KSgfLaAMhotOatn root@zynq7045_net
Fingerprint: md5 cc:74:8a:11:cf:72:33:34:f5:4d:53:2b:ce:ac:c9:d6
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2018.1 zynq7045_neoz"??ttyPS0
zynq7045_net login: root
Password:
root@zynq7045_net:~# macb e000b000.ethernet eth0: link down
macb e000b000.ethernet eth0: link up (1000/Full)
Hi linken_mu@163.com
Could you please share the device tree file being used in linux?
Best Regards
Shabbir
It seems network parameter issue.
Would you make sure default gateway setting and execute the following command to confirm arp table ?
$ arp -a
Best regards,
