customize system-user.dtsi file for device tree in petalinux 2017
I implemented my ip and test the block design on sdk successfully , now I want to add it to the pynq board (zynq ps) but I don't know how should I modify the user's device tree file , with what and based on what should I do so  .
There a photo attached with my block design any help would be greatly appreciated as it's my first time using petalinux .
Mohamed Taher
Do you have a linux device driver for this IP. Only a baremetal driver (one you used in sdk) is created by the tools.
If you want to test in linux, the you can try a UIO as this would be quicker
Yes I have two main files created by the tools which are Xtesting.c and Xtesting.h . Are these what you mean ?
I don't get what do you mean by trying the UIO , forgive me I am new to this .
Mohamed Taher
You will need to create a linux device driver, or you can use the UIO
https://www.kernel.org/doc/html/v4.15/driver-api/uio-howto.html
