customize u-boot
I am using Petalinux 2016.4 and what I need now is to customize the generated u-boot.elf file by adding my own board init code (I have a custom board).
Can someone point me to the file/files/directories where my code can be placed and where it will be included for the u-boot.elf file build with the "petalinux-build -c u-boot" command, please?
Thank you for any advices...
Jirka
Kindly note: please mark the Answer as "Accept as solution" if information provided is helpful and/or give Kudos to a post. Thank you!
Finally, I've found the files I need!!!
My Krusader got always frozen while searching the text for the board_init() function and moreover, I've overlooked the board.c file within the search results when searching for files... I am getting old, blind or tired :-)
So the u-boot board.c file is located on the following path:
<project_root>/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/build/source/board/xilinx/zynq
Maybe it will help to someone in future...
Thanks to everyone for reading my post and trying find a solution :-)
Jirka
Voyager
Voyager
If i remember rightly,
cp <your_src_dir>/ps7_init_gpl.{c,h} output/build/uboot-xilinx-v2016.4/board/xilinx/zynq/
Trigger
Thank you for your fast reply.
I've found that there are 3 directories within the Petalinux project where the ps7_init_gpl.{c,h} are located:
1) <project_path>/components/plnx_workspace/device-tree-generation/ps7_init_gpl.c
2) <project_path>/components/plnx_workspace/fsbl_hwproj/ps7_init_gpl.c
3) <project_path>/project-spec/hw-description/ps7_init_gpl.c
Which one will be the best choice, please?
Jirka
Really nobody who knows?
So I have another question that could solution for me - what I need to change to build uImage from the petalinux project insteed of image.ub, please?
Jirka
Voyager
Voyager
I think the better is :
but i'm not sure because I build my custom OS with Yocto :S
You can also try one by one...
Trigger
Thank you but no one of this three files is included in the u-boot.elf file build...
I am also using the Yocto build (Petalinux tools 2016.4).
I have found how to change some configuration, e.g. environment variables, etc. (inside the <project_root>/project-spec/meta-user/recipes-bsp/u-boot/files/platform-top.h) for the u-boot file but it is not what I need to achieve. I need to add custom code to make some settings to my hardware. I need this settings are made in u-boot, before the (peta)linux loading.
I have the settings defined in functions in the settings.c file I wrote. Before, I used the Linaro linux - there is a Bootloader project including a folder named "board" in which the board.c file is located. I've added my settings.c file inside this folder and made the "extern" declaration of the settings.c functions inside the board.c and calling of this functions inside the board.c "int board_init()" function. Everything was built and working fine.
Now I need move my project from the Linaro to the Petalinux . I am able to build everything and run the Petalinux on my custom board except my settings that need to be processed by u-boot.
I do not know which ".c" files are used for building the u-boot.elf. I can't find the equivalent of Linaro "board.c" file or the "board_init()" function.
Xilinx or other Petalinux experts, PLEASE, help me to solve this problem...
Thank you for every advices,
Jirka
Jirka
I'm in the process of migrating from Vivado/Petalinux 15.2 to 17.2. As mentioned here I have some custom changes in board.c and zynq_i2c.c. In the earlier versions the source is <plnx-projroot>/components/u-boot/u-boot-plnx. Once I make the changes they are permanent.  However with the Yocto there is no u-boot source. When I enter petalinux-config -c u-boot, It is creating the folder as mentioned above in the <plnx-projroot>/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx+gitAUTOINC+5290eb544b-r0/build/ and I can drop my changes and build the u-boot. However on successful build it wipes out the source folder.
I am sure many of the users will have the custom changes and modify the u-boot as per their requirements. Where the new petalinux is expected to drop these changes? It looks to me it is fetching the changes from git repository.I hope it is bound to a tagged version and downloaded and resides locally.
Can someone shed some light on this
Seetharam
Hi all,
This is done based on
1. boot rom design
2. board_init_f()
3. board_init_r()
4. main loop()
First & Second are not able to reduce the code because they provides minimal functionality need for u-boot and board initlization,
third step talks about board_init_r (), peripherals required by board are intilized here, if you want to reduce boot code size, identify the Peripherals need in u-boot level and reduce it to minimal based on custom board.
Give kudos if the post is helpful.
Thanks & Regards
Satish G
G Satish Kumar
