debug operations to fix an ethernet phy that is not working in linux.
Bought a HTG-Z920 dev board and a HTG-FMC-8639 FMC board.  Cannot get the ethernet phy to work on the FMC daughter board.  The phy leds do not light up nor can i see anything from linux command line.
What are the steps to debugging the issue?
What I have done already.
Double checked connections through the FMC.
Checked Voltage levels on the daughter card.
Using GEM3 on zynqMP.  Double checked vivado project when setting up zynqMP IP.  Exported hardware definition.
Created Petalinux project from scratch using hardware definition file (SDK folder as a whole)
Double checked TI phy support in the kernel was enabled.
Generated BOOT.BIN and image.ub.
Booted from generated code.
Relevant phy messages.
[    1.618327] macb ff0e0000.ethernet eth0: Could not attach to PHY
Configuring network interfaces... Cannot find device "eth0"
ifconfig returns only the loopback interface.
Where do i go from here to figure this problem out?
Attached Boot Log
Hello @coreyhahn,
Have you tried an electrical continuity test for each of the conductors?
You should be able to do so with a cut Ethernet cable and an ohmmeter.
After that, use an Ethernet loop-back connector to see if the link talks to its self.
Finally, if that all works, try changing your Ethernet cable.
Good Luck!
Peimann
Kind Regards,
Peimann, S. M.
Toddlers are the Storm-Troopers of the Great God Entropy.
Physics: Not Just a Good Idea, It's THE LAW.
Hi @coreyhahn,
Do you have your phy sub node in GEM3 device-tree node.
Refer ZCU102 eval board device-tree https://github.com/Xilinx/device-tree-xlnx/blob/master/device_tree/data/kernel_dtsi/2018.3/BOARD/zcu102-rev1.0.dtsi#L42-L53
Sandeep
I do.
zynqmp.dtsi
gem3: ethernet@ff0e0000 {
compatible = "cdns,zynqmp-gem", "cdns,gem";
status = "disabled";
interrupt-parent = <&gic>;
interrupts = <0 63 4>, <0 63 4>;
reg = <0x0 0xff0e0000 0x0 0x1000>;
clock-names = "pclk", "hclk", "tx_clk";
#address-cells = <1>;
#size-cells = <0>;
#stream-id-cells = <1>;
iommus = <&smmu 0x877>;
power-domains = <&pd_eth3>;
system-conf.dtsi
&gem3 {
local-mac-address = [00 0a 35 00 22 01];
This problem is software related.  Upon boot the zynq is not even sending the clock to the TI phy.
Hi @coreyhahn,
I don't see the phy sub nodes mentioned in your device-tree.
Sandeep
So after some debugging i have gotten to the point where the linux kernel will pick up the ti driver and it seems to think the phy is there but neither UBoot or Linux can get auto negotiation to work.  I still do not see activation and link lights from the phy.
My current dtsi
&gem3 {
status = "okay";
phy-handle = <&phy0>;
phy-mode = "rgmii-id";
xlnx,has-mdio = <0x1>;
mdio {
phy0: phy@12 {
compatible = "ti,dp83867", "ethernet-phy-ieee802.3-c22";
device_type = "ethernet-phy";
reg = <12>;
ti,rx-internal-delay = <0x8>;
ti,tx-internal-delay = <0x0>;
ti,fifo-depth = <0x01>;
ti,dp83867-rxctrl-strap-quirk;
While in UBoot I captured some data with the mii tool.  The dumps do not look right.  They are all ones and they do not look like other mii dumps in the forums.
ZynqMP> mii device
MII devices: 'eth0'
Current device: 'eth0'
ZynqMP> mii dump 0 0
0. (ffff) -- PHY control register --
(8000:8000) 0.15 = 1 reset
(4000:4000) 0.14 = 1 loopback
(2040:2040) 0. 6,13 = b11 speed selection = 10 Mbps
(1000:1000) 0.12 = 1 A/N enable
(0800:0800) 0.11 = 1 power-down
(0400:0400) 0.10 = 1 isolate
(0200:0200) 0. 9 = 1 restart A/N
(0100:0100) 0. 8 = 1 duplex = full
(0080:0080) 0. 7 = 1 collision test enable
(003f:003f) 0. 5- 0 = 63 (reserved)
ZynqMP> mii dump 0 1
1. (ffff) -- PHY status register --
(8000:8000) 1.15 = 1 100BASE-T4 able
(4000:4000) 1.14 = 1 100BASE-X full duplex able
(2000:2000) 1.13 = 1 100BASE-X half duplex able
(1000:1000) 1.12 = 1 10 Mbps full duplex able
(0800:0800) 1.11 = 1 10 Mbps half duplex able
(0400:0400) 1.10 = 1 100BASE-T2 full duplex able
(0200:0200) 1. 9 = 1 100BASE-T2 half duplex able
(0100:0100) 1. 8 = 1 extended status
(0080:0080) 1. 7 = 1 (reserved)
(0040:0040) 1. 6 = 1 MF preamble suppression
(0020:0020) 1. 5 = 1 A/N complete
(0010:0010) 1. 4 = 1 remote fault
(0008:0008) 1. 3 = 1 A/N able
(0004:0004) 1. 2 = 1 link status
(0002:0002) 1. 1 = 1 jabber detect
(0001:0001) 1. 0 = 1 extended capabilities
ok a new question.  what is mii info reporting?
My device tree has a phy at address 31
&gem3 {
    status = "okay";
	mdio {
		phy0: phy@31 {
            status = "okay";
			reg = <31>;
but no matter what address i set the phy address to in the device tree, mii info produces.
ZynqMP> mii info
PHY 0x0C: OUI = 0x80028, Model = 0x23, Rev = 0x01,  10baseT, HDX
Why is the phy address listed as 0xc (12)?  Always.
Ok so.
mii info
is reporting all the phy devices it sees.   Which in my case is the correct case of a phy at addr 12/0x0C  it was doing the right thing.
an equivalent command is
mii info 0x0C
Now when I run
mii dump 0x0C 0x00
I get expected results (non-all ones).
Hope this can help someone in the future.
