device tree - how to override nodes?
- IP, Version: AXI JTAG, 1.0
- Vivado, SDK, Petalinux: 2017.4
- Device:      Zynq-7000
hello,
I added the AXI-JTAG IP-Core from Xilinx to my hardware platform. To use it in my petalinux platform the toolset already generated a device-tree for me, like so:
pl.dtsi:
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Thu May 17 18:41:26 2018
    amba_pl: amba_pl {
        #address-cells = <1>;
        #size-cells = <1>;
        compatible = "simple-bus";
        ranges ;
        axi_jtag_0: axi_jtag@43c00000 {
            compatible = "xlnx,axi-jtag-1.0";
            reg = <0x43c00000 0x10000>;
            xlnx,tck-clock-ratio = <0x10>;
However, I'd like to use the device with UIO driver, so I need it to be defined like this:
system-user.dtsi:
&amba {
    ranges ;
    axi_jtag_0: axi-jtag@43c00000 {
        compatible = "generic-uio";
Adding this node to system-user.dtsi is conflicting with the generated node since axi_jtag_0 already exists. Is there a way to override or overload the previous declaration?
Thank you
Re: device tree - how to override nodes?
The parameters given in the system-user.dtsi will overwrite parameters in the original node.
See wiki below:
http://www.wiki.xilinx.com/Testing+UIO+with+Interrupt+on+Zynq+Ultrascale
You can update a node using the system-user.dts file in the devicetree recipe.
See page 75:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug1144-petalinux-tools-reference-guide.pdf#page74
hello @stephenm,
I think I was not clear in describing my actual problem.
My problem is, the node axi_jtag_0 had already automatically been added, but not the way I wanted. It is missing the "generic-uio" property value for the "compatible" property name.
Following UG1144, page 75 lets me add information to the automatically generated device-tree.That is, I am able to add the node axi_jtag_0 again, to the device tree which leads to a conflict of these two.
Shall I give the node a different name, like axi_jtag_1, or can I prevent the generation of axi_jtag_0 node in pl.dtsi?
What I want to do is this:
source: http://www.wiki.xilinx.com/Device+Tree+Tips -> Device Trees For Dummies
I might want to do the same, In the figure above ocp is defined twice, in two different files. My attempt to do that resulted in a compilation error of the dtb.
See wiki below:
