pmaurice
dma-proxy
I am using vivado/vitis/petalinux 2020.2
I want to use the dma-proxy driver to access my pl axi dma.
so far I took a look to theses webpage:
https://forums.xilinx.com/t5/Embedded-Linux/dma-proxy-device-tree-modification-petalinux-2018-3/m-p/1061428#M39229
https://forums.xilinx.com/t5/Embedded-Linux/dma-proxy-tutorial-xilinx-vdma-errors/td-p/1062464
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842418/Linux+DMA+From+User+Space
I have added in system-user.dtsi :
dma_proxy {
compatible ="xlnx,dma_proxy";
dmas = <&axi_dma_0 0
&axi_dma_0 1>;
dma-names = "dma_proxy_tx", "dma_proxy_rx";
I have no problem to build, when I boot on the zynq and I do ls /dev , I only see a node called dmaproxy, there is no dma_proxy_tx / rx node created. And when I do lsmod , I see the dmaproxy driver loaded.
when I load/unload manually the driver it doesn't do anything more.
What do I need to do , to have access to dma_proxy_tx and dma_proxy_rx node ??????
This thing is suppose to be straight forward but like every time , Xilinxs lack of RECENT AND WORKING documentation leads me here again and again.
pmaurice
Apparently, on a zynq ultrascale+ the video coded units auto-install a dmaproxy module which is loaded as a char device. But that dmaproxy driver is not the one needed to perform dma.
Basically, you need to add module in petalinux and drop the code of dma-proxy (posted on another forum thread), add the node in device tree and once you build and load the driver , i have saw dma_proxy_tx and dma_proxy_rx
pmaurice
