do CPIO error code 1 during petalinux compile
The log helpfully just has the error message bitbake failed. Anyone have any idea what an error code 1 is?
Re: do CPIO error code 1 during petalinux compile
lol the
The first error inthe log:
p-proj/xilinx-zcu111-2019.1/build/tmp/work/zcu111_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp/log.do_image$
the contents of that file :|
DEBUG: Executing python function do_image
NOTE: Executing mklibs_optimize_image ...
DEBUG: Executing shell function mklibs_optimize_image
DEBUG: Shell function mklibs_optimize_image finished
NOTE: Executing reproducible_final_image_task ...
DEBUG: Executing shell function reproducible_final_image_task
DEBUG: Shell function reproducible_final_image_task finished
DEBUG: Python function do_image finished
Oddly
petalinux-build -x mrproper
and rebuilding it worked fine
disregard. It is still giving me this error but here's some additional log info i got this time
Log data follows:
| DEBUG: Executing python function set_image_size
| DEBUG: 3069456.000000 = 2361120 * 1.300000
| DEBUG: 3171856.000000 = max(3069456.000000, 65536)[3069456.000000] + 1
| DEBUG: 3171856.000000 = int(3171856.000000)
| DEBUG: 3171856 = aligned(3171856)
| DEBUG: returning 3171856
| DEBUG: Python function set_image_size finished
| DEBUG: Executing python function extend_recipe_sysroot
it apparently is caused by me using
IMAGE_INSTALL_append = " nano"
to install nano in the local.conf. Apparently petalinux doesn't like people using image install append?
