Observer mascot02
emaclite problems with 14.7 (cache err??)
the xilinx_emaclite.ko  was useful when I  insmod it the first time;
but if i rmmod it then try insmod and rmmod for test ;
it faile at the third time,  and  the kernel  debug as fallow:
i can't use top cmd or any other about cache ;
how can i fix it ?
ernel BUG at c009de34 [verbose debug info unavailable]
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
Modules linked in: [last unloaded: xilinx_emaclite]
CPU: 0 PID: 803 Comm: top Not tainted 3.10.0-xilinx #3
task: ce0bc800 ti: cd24c000 task.ti: cd24c000
PC is at cache_alloc_refill+0x22c/0x590
LR is at cache_alloc_refill+0x88/0x590
pc : [<c009de34>]    lr : [<c009dc90>]    psr: a0000093
sp : cd24dda8  ip : ffffffff  fp : cd24df78
r10: 0000000c  r9 : cdc04e78  r8 : ce001504
r7 : cd2c31c0  r6 : ce001500  r5 : ce017840  r4 : ce0003c0
r3 : 00000002  r2 : 01330133  r1 : 00000000  r0 : 00000000
Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 18c5387d  Table: 0d21c04a  DAC: 00000015
Process top (pid: 803, stack limit = 0xcd24c238)
Stack: (0xcd24dda8 to 0xcd24e000)
dda0:                   000000d0 cde04e58 00000000 cdc04e78 00000000 ce0003c0
ddc0: 000000d0 60000013 cd24c020 c00bd074 cdc04e78 cd24decc cd24df78 c009e23c
dde0: 00000060 00000003 ce09cd40 ce09cd40 cde04e78 c00e963c cd13f440 cd2a4380
de00: ce09cd40 c00e3210 ce09cd40 cde04e78 c00e3178 ce09cd48 00000000 c00a08cc
de20: 00000000 cd24decc 00000000 cd24deb8 cde04ec0 ce09cd40 cd24decc c00a09b0
de40: cd24df00 c00addc0 cd1b8740 cd21c000 00000028 cd2ca180 00000000 00000000
de60: 00000000 00000000 176d180b cdc026f0 00000000 00000024 ce02e2d0 cdc026f0
de80: cde04e78 0124df78 ffffff9c cd24df00 ce09cd40 cd24df78 ce164000 cd24decc
dea0: cd24c000 00000041 be8a1b8c c00ae044 cd24decc 00000000 ce02e2d0 cde16b30
dec0: 00000001 00000006 00000000 00000000 cd24df50 cd24df78 00000001 ce164000
dee0: ffffff9c c000e384 cd24c000 00000000 be8a1b8c c00ae634 00000041 000a2a08
df00: ce02e2d0 cde16b30 176d180b 00000004 ce164010 c009e364 00000000 c00bd9d0
df20: cde04e78 00000101 00000002 00000000 00000000 00000000 00000400 cd2c3240
df40: ce04f9c0 c00b8c74 00000000 00000000 ffffff9c ce164000 00000001 00000003
df60: ffffff9c ce164000 00000001 c00a1880 00000006 c000e384 00000000 00000000
df80: 00000024 00000100 cd251980 000a3008 00090c5d 00000008 00000005 c000e384
dfa0: 00000000 c000e200 000a3008 00090c5d 000897c0 00000000 000001b6 000001b6
dfc0: 000a3008 00090c5d 00000008 00000005 00000000 000ab660 00000000 be8a1b8c
dfe0: 00000000 be8a1b2c b6e0e48c b6e5ffcc 60000010 000897c0 00000000 00000000
[<c009de34>] (cache_alloc_refill+0x22c/0x590) from [<c009e23c>] (__kmalloc+0xa4/0x100)
[<c009e23c>] (__kmalloc+0xa4/0x100) from [<c00e963c>] (stat_open+0x40/0x98)
[<c00e963c>] (stat_open+0x40/0x98) from [<c00e3210>] (proc_reg_open+0x98/0x11c)
[<c00e3210>] (proc_reg_open+0x98/0x11c) from [<c00a08cc>] (do_dentry_open.isra.15+0x188/0x248)
[<c00a08cc>] (do_dentry_open.isra.15+0x188/0x248) from [<c00a09b0>] (finish_open+0x24/0x38)
[<c00a09b0>] (finish_open+0x24/0x38) from [<c00addc0>] (do_last.isra.40+0x8e4/0xac0)
[<c00addc0>] (do_last.isra.40+0x8e4/0xac0) from [<c00ae044>] (path_openat.isra.41+0xa8/0x400)
[<c00ae044>] (path_openat.isra.41+0xa8/0x400) from [<c00ae634>] (do_filp_open+0x2c/0x78)
[<c00ae634>] (do_filp_open+0x2c/0x78) from [<c00a1880>] (do_sys_open+0xe4/0x170)
[<c00a1880>] (do_sys_open+0xe4/0x170) from [<c000e200>] (ret_fast_syscall+0x0/0x30)
Code: e59d6000 e006700a e3570000 0a000000 (e7f001f2)
---[ end trace 33f89b67dcc12c5c ]---
note: top[803] exited with preempt_count 1
BUG: scheduling while atomic: top/803/0x40000002
CPU: 0 PID: 803 Comm: top Tainted: G      D      3.10.0-xilinx #3
[<c001421c>] (unwind_backtrace+0x0/0x11c) from [<c0011224>] (show_stack+0x10/0x14)
[<c0011224>] (show_stack+0x10/0x14) from [<c03c043c>] (__schedule_bug+0x48/0x60)
[<c03c043c>] (__schedule_bug+0x48/0x60) from [<c03c3c7c>] (__schedule+0x68/0x508)
[<c03c3c7c>] (__schedule+0x68/0x508) from [<c0043160>] (__cond_resched+0x24/0x34)
[<c0043160>] (__cond_resched+0x24/0x34) from [<c03c41a8>] (_cond_resched+0x34/0x44)
[<c03c41a8>] (_cond_resched+0x34/0x44) from [<c00b8b48>] (put_files_struct+0x94/0xe4)
[<c00b8b48>] (put_files_struct+0x94/0xe4) from [<c0024bd4>] (do_exit+0x360/0x850)
[<c0024bd4>] (do_exit+0x360/0x850) from [<c001156c>] (die+0x344/0x390)
[<c001156c>] (die+0x344/0x390) from [<c000833c>] (do_undefinstr+0x138/0x154)
[<c000833c>] (do_undefinstr+0x138/0x154) from [<c000deac>] (__und_svc_finish+0x0/0x14)
Exception stack(0xcd24dd60 to 0xcd24dda8)
dd60: 00000000 00000000 01330133 00000002 ce0003c0 ce017840 ce001500 cd2c31c0
dd80: ce001504 cdc04e78 0000000c cd24df78 ffffffff cd24dda8 c009dc90 c009de34
dda0: a0000093 ffffffff
[<c000deac>] (__und_svc_finish+0x0/0x14) from [<c009de34>] (cache_alloc_refill+0x22c/0x590)
Segmentation fault
Observer mascot02
Re: emaclite problems with 14.7 (cache err??)
insmod xilinx_emaclite.ko  at the third time  kernel debug :
insmod
xilinx_emaclite 40e00000.ethernet: Device Tree Probing
------------[ cut here ]------------
Kernel BUG at c009de34 [verbose debug info unavailable]
Modules linked in: xilinx_emaclite(+) [last unloaded: xilinx_emaclite]
CPU: 0 PID: 770 Comm: insmod Not tainted 3.10.0-xilinx #3
task: ce0a2800 ti: cd2e2000 task.ti: cd2e2000
sp : cd2e3d20  ip : ffffffff  fp : 00000001
r10: 0000000c  r9 : cd2b1e80  r8 : ce001504
r7 : ce165640  r6 : ce001500  r5 : ce017840  r4 : ce0003c0
r3 : 00000002  r2 : 00da00da  r1 : 00000000  r0 : 00000000
Control: 18c5387d  Table: 0d33404a  DAC: 00000015
Process insmod (pid: 770, stack limit = 0xcd2e2238)
Stack: (0xcd2e3d20 to 0xcd2e4000)
3d20: 000080d0 00000000 00000000 00000000 00000020 ce0003c0 000080d0 60000013
3d40: cd2e2018 00000001 cd2b1e80 00000001 00000001 c009e23c c04c7e1d c04c7e17
3d60: 000000b0 c03458f8 00000001 c032f71c ce0e1c10 bf00f42c ce0e1c10 ce0e1c00
3d80: bf00fa40 cd2b1e80 00000001 c03458ec 00000001 00000001 00000001 bf00e6ec
3da0: 00000000 c00ef624 ce0e1c10 c021565c ce079e44 00000003 ce0e0c48 00000000
3dc0: bf00f42c ce0e1c10 ce0e1c18 ce0e1c10 bf00f42c bf00f42c 00000000 bf00fa40
3de0: 00000001 c020e254 c020e240 c020cf78 bf00f42c ce0e1c10 ce0e1c10 ce0e1c44
3e00: bf00f42c c020d1d4 bf00f42c c020d174 00000000 c020b6a4 ce079e1c ce0db774
3e20: bf00f42c cd2572c0 c0582ce0 c020c574 bf00f340 00000001 bf00f42c cd2e3e70
3e40: 00000000 00000000 bf00fa40 c020d864 bf012000 cd2e3e70 00000000 00000000
3e60: bf00fa40 cd2b1e80 00000001 c000862c bf012000 00000000 00000001 bf00f9f8
3e80: bf00f9f8 00400100 bf00fa04 00000000 bf00fa40 00000001 00000001 c005c3b0
3ea0: bf00fa04 00007fff c01bf5c8 c00960c0 cd266c80 00000000 00000000 bf00fb48
3ec0: bf00f9f8 d087b224 00000000 000a3008 6e72656b 00006c65 00000000 00000000
3ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
3f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
3f20: 00000000 c04ef674 000000d2 000a3018 000049dd 000a3008 00000080 c000e384
3f40: cd2e2000 00000000 00000000 c005c75c 00000010 c00a3274 d0878000 000049dd
3f60: d087ad24 d087abc7 d087c2bc 00001b48 00001e78 bf00f9c8 00000002 00000000
3f80: 00000020 00000021 00000018 00000013 00000011 00000000 000049dd be980f24
3fa0: 0009a53f c000e200 000049dd be980f24 000a3018 000049dd 000a3008 000a07c4
3fc0: 000049dd be980f24 0009a53f 00000080 0000017d be980e34 00000002 00000000
3fe0: be980c60 be980c50 00015894 b6f39850 60000010 000a3018 00000000 00000000
[<c009e23c>] (__kmalloc+0xa4/0x100) from [<c032f71c>] (alloc_netdev_mqs+0x74/0x244)
[<c032f71c>] (alloc_netdev_mqs+0x74/0x244) from [<c03458ec>] (alloc_etherdev_mqs+0x18/0x24)
[<c03458ec>] (alloc_etherdev_mqs+0x18/0x24) from [<bf00e6ec>] (xemaclite_of_probe+0x2c/0x338 [xilinx_emaclite])
[<bf00e6ec>] (xemaclite_of_probe+0x2c/0x338 [xilinx_emaclite]) from [<c020e254>] (platform_drv_probe+0x14/0x18)
[<c020e254>] (platform_drv_probe+0x14/0x18) from [<c020cf78>] (driver_probe_device+0x130/0x32c)
[<c020cf78>] (driver_probe_device+0x130/0x32c) from [<c020d1d4>] (__driver_attach+0x60/0x84)
[<c020d1d4>] (__driver_attach+0x60/0x84) from [<c020b6a4>] (bus_for_each_dev+0x4c/0x80)
[<c020b6a4>] (bus_for_each_dev+0x4c/0x80) from [<c020c574>] (bus_add_driver+0xcc/0x238)
[<c020c574>] (bus_add_driver+0xcc/0x238) from [<c020d864>] (driver_register+0x9c/0x13c)
[<c020d864>] (driver_register+0x9c/0x13c) from [<c000862c>] (do_one_initcall+0xbc/0x170)
[<c000862c>] (do_one_initcall+0xbc/0x170) from [<c005c3b0>] (load_module+0x1afc/0x1db4)
[<c005c3b0>] (load_module+0x1afc/0x1db4) from [<c005c75c>] (SyS_init_module+0xf4/0x100)
[<c005c75c>] (SyS_init_module+0xf4/0x100) from [<c000e200>] (ret_fast_syscall+0x0/0x30)
---[ end trace 0de6b11a23bff31b ]---
note: insmod[770] exited with preempt_count 1
BUG: scheduling while atomic: insmod/770/0x40000002
CPU: 0 PID: 770 Comm: insmod Tainted: G      D      3.10.0-xilinx #3
Exception stack(0xcd2e3cd8 to 0xcd2e3d20)
3cc0:                                                       00000000 00000000
3ce0: 00da00da 00000002 ce0003c0 ce017840 ce001500 ce165640 ce001504 cd2b1e80
3d00: 0000000c 00000001 ffffffff cd2e3d20 c009dc90 c009de34 a0000093 ffffffff
./net_test: line 16:   770 Segmentation fault      insmod xilinx_emaclite.ko
ifconfig: SIOCGIFFLAGS: No such device
