mishuk
enable watchdog in u-boot
Hi !
We use zynq-7000 SoC.  We enable watchdog support in DTS file and watchdog works in Linux fine.  How can I get watchdog working in u-boot ?  I would like to load recovery linux image in case of loading linux freezes (broken image, broken rootfs, etc).  Is it possible ?
Tags (2)
kayas257
I had enabled watchdog in u boot by adding
#DEFINE CONFIG_WD
#DEFINE CONFIG_WDT_CDNS
In platform-top.h file in petalinux,
Hope this solves your problem
mishuk
I added CONFIG_WD and CONFIG_WDT_CDNS
through project-spec/meta-user/recipes-bsp/u-boot/files/user_XXX.cfg and rebuild u-boot. I have tested watchdog timer in u-boot : it does not work.  What have I missed ? How can I tune watchdog parameters ?
kayas257
Did you set pmu flag to enable hardware watchdog?
Is it working in linux?
Which petalinux version ru using?
mishuk
Watchdog works in linux as expected.
We use petalinux 2017.2
Where must I enable PMU flag to enable hardware watchdog ?
kayas257
Sorry not for zynq 7000, pmu flags are only for zynq ultra scale, I have similar issue with uboot after upgrading to petalinux 2020.1, I will update once I solve it, but in 2019.2 it worked for me by adding that lines in platform-top.h file.
kayas257
I found the solution Please also enable this flags in .cfg
CONFIG_SYSRESET_WATCHDOG=y
CONFIG_SPL_WATCHDOG_SUPPORT=y
CONFIG_SPL_WDT=y
CONFIG_WDT_CDNS=y
CONFIG_WDT=y
