Observer lss1776
error :sdboot not define
I test a function on the zedboard paltform,but the liunx operate can't start.The problem is shown in the picture
Scholar watari
Re: error :sdboot not define
Hi @lss1776
I see.
Would you refer the following AR #59311 ?
https://www.xilinx.com/support/answers/59311.html
Scholar watari
Hi @lss1776
Could you share uEnv.txt to resolve this issue ?
Observer lss1776
This is my uEnv.txt
uenvcmd=run adi_sdboot
adi_sdboot=echo Copying Linux from SD to RAM... && fatload mmc 0 0x3000000 ${kernel_image} && fatload mmc 0 0x2A00000 ${devicetree_image} && if fatload mmc 0 0x2000000 ${ramdisk_image}; then bootm 0x3000000 0x2000000 0x2A00000; else bootm 0x3000000 - 0x2A00000; fi
bootargs=console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootdelay=1 init=/sbin/init mem=500M uio_pdrv_genirq.of_id="generic-uio"
The operate could start on the other zedboard paltform,my zedboard can't ,but my zedboard is ok.
Scholar watari
Hi @lss1776
Could you make sure SDIO level translator (TI TXS02612), its voltage and SDxCD pin on your ZedBoard ?
I suspect them.
Would you try them ?
Observer lss1776
Sorry,I'm not sure SDIO level translator,and I don't konw how to modify it.My XDC file doesn't contain SDIO pin.
Hi @lss1776,
The right command seems to be run adi_sdboot isn't it ?
Cheers,
Trigger
Observer lss1776
Hi @trigger
The start files could run on the other zedboard,but my zedboard is ok.
Scholar watari
Hi @lss1776
Can you measure voltage on these ports on SDIO level shift device by oscilloscope ?
I suspect this device malfunction. So I suggest to make sure it by oscilloscope.
[Note]
Would you refer "IC8 TX502612RTWR" on page 6 of following schema ?
http://zedboard.org/support/documentation/1521
Schematics -> ZedBoard Schematics Rev. D. 2 -> Download
Observer lss1776
Hi @watari
I don't have oscilloscope,so I test another IP boot.bin without linux, the project could start.So I consider my zedboard is ok.
Scholar watari
Hi @lss1776
Got it.
Could you change the following line in uEnv.txt ?
[Original]
[Modified]
adi_sdboot=echo Copying Linux from SD to RAM... ;fatload mmc 0 0x3000000 ${kernel_image};fatload mmc 0 0x2A00000
Observer lss1776
Hi @watari
I modify my uEnv.txt,but the linux still can't start.Someone tells me the error maybe involve in flash,but he forgets how to modify it.
Scholar watari
Hi @lss1776
I see.
