ethernet disabled
Hi:
I'm trying to debug my app with XSDK in petalinux 2015.04 qemu enviroment, but linux cannot find eth0.
boot information:
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
with help of qemu document(see attachment), subsystems/linux/configs/device-tree/system_top.dts modified like this
&gem0 {
   phy-handle = <&phy0>;
   phy-mode = "rgmii-id";
   mdio {
	   #address-cells = <1>;
	   #size-cells = <0>;
	   phy0: phy@0 {
	      compatible = "marvell,88e1510";
	      device_type = "ethernet-phy";
	      reg = <0>;
By using this command to check DTB:
../../build/linux/kernel/xlnx-3.19/scripts/dtc/dtc -I dtb -O dts -o system.dts system.dtb
system.dts indicates port disabled:
ethernet@e000b000 {
			compatible = "cdns,gem";
			reg = <0xe000b000 0x1000>;
			status = "disabled";
			interrupts = <0x0 0x16 0x4>;
			clocks = <0x1 0x1e 0x1 0x1e 0x1 0xd>;
			clock-names = "pclk", "hclk", "tx_clk";
			#address-cells = <0x1>;
			#size-cells = <0x0>;
			phy-handle = <0x4>;
			mdio {
				phy@0 {
					reg = <0x0>;
					linux,phandle = <0x4>;
					phandle = <0x4>;
The same operation work well at ptlnx 2015.02, status is okay.
Any help is welcome...
Re: ethernet disabled
Solution:
Modifiy subsystems/linux/configs/device-tree/zynq-7000.dtsi as follows:
         gem0: ethernet@e000b000 {
             status = "okay";
             interrupts = <0 22 4>;
             clocks = <&clkc 30>, <&clkc 30>, <&clkc 13>;
             #size-cells = <0>;
But petalinux 2015.02 do not need this step. Cannot tell why.
Solution:
             status = "okay";
             #size-cells = <0>;
