rjlu
fail to build user module in petalinux 2017.2
I am using Petalinux 2017.2 running on Ubuntu 16.04.
I am generating a template module using
petalinux-create -t modules -n laserCNTRL --enable
 After adding some simple lines to laserCNTRL.c file, run
   petalinux-build -c laserCNTRL
But  the module build fails, can anyone tell the reason?
~/Z7_project/z7_io_linux$ petalinux-build -c laserCNTRL
[INFO] building laserCNTRL
[INFO] sourcing bitbake
INFO: bitbake laserCNTRL
Loading cache: 100% |###################################################################| Time: 0:00:00
Loaded 3235 entries from dependency cache.
Parsing recipes: 100% |#################################################################| Time: 0:00:01
Parsing of 2447 .bb files complete (2414 cached, 33 parsed). 3237 targets, 224 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |##############################################################| Time: 0:00:06
Checking sstate mirror object availability: 100% |######################################| Time: 0:00:00
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: petalinux-user-image-1.0-r0 do_rootfs: laserCNTRL not found in the feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all) in /home/owbama/Z7_project/z7_io_linux/build/tmp/deploy/rpm.
ERROR: petalinux-user-image-1.0-r0 do_rootfs: This is often caused by an empty package declared in a recipe's PACKAGES variable. (Empty packages are not constructed unless ALLOW_EMPTY_<pkg> = '1' is used.)
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/owbama/Z7_project/z7_io_linux/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/temp/log.do_rootfs.11231
ERROR: Task (/home/owbama/Z7_project/z7_io_linux/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2403 tasks of which 2389 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build laserCNTRL
webtalk failed:PetaLinux statistics:extra lines detected:notsent_nofile!
webtalk failed:Failed to get PetaLinux usage statistics!
rjlu
I figure out : there should not have any upper case letter in the module name.
rjlu
Because it's a simplest try with module following UG1144, it seem to be some petalinux interal bugs. Did anyone has these problems with module creation in petalinux 2017.2??
rjlu
I check related directories:
    Under. /build/temp/work/plnx_arm-xilinx-linux-gnueabi/laserCNTRL/1.0-r0/deploy-rmps/plnx_arm, there are two subdirctories, one is ./kernel-module-lasercntrl-1.0-r0.plnx_arm.rpm, in which laserCNTRL.ko stays, the other is ./laserCNTRL-dev-1.0-r0.plnx_arm.rpm, an empty directory.
   At the same time, under . /build/temp/work/plnx_arm-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/rpms/plnx_arm/, a copy of laserCNTRL-dev-1.0-r0.plnx_arm.rpm exists, but is empty.
   So do_rootfs uses this empty package and claims an error.
   Why does the petalinux not copy  kernel-module-lasercntrl-1.0-r0.plnx_arm.rpm to be used by do_rootfs?
   How to creat and build modules with petalinux 2017.2 correctly??
rjlu
At the same time, a copy of laserCNTRL-dev-1.0-r0.plnx_arm.rpm  which is also empty is found under . /build/temp/deploy/rpm/plnx_arm/.
rjlu
