mspalpsahan
failed build petalinux
hi all
hi
i take error while build petalinux.  i don't understand from this error. would you help me.
$ petalinux-build -x mrproper
$ petalinux-build
| arm-xilinx-linux-gnueabi-gcc --sysroot=/opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/recipe-sysroot -E -Wp,-MD,./.u-boot.lds.d -D__KERNEL__ -D__UBOOT__ -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -mtune=generic-armv7-a -I/opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/arch/arm/mach-zynq/include -Iinclude -I/opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/include -I/opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/arch/arm/include -include /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/include/linux/kconfig.h -nostdinc -isystem /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/recipe-sysroot-native/usr/bin/arm-xilinx-linux-gnueabi/../../lib/arm-xilinx-linux-gnueabi/gcc/arm-xilinx-linux-gnueabi/8.2.0/include -ansi -include /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/include/u-boot/u-boot.lds.h -DCPUDIR=arch/arm/cpu/armv7 -D__ASSEMBLY__ -x assembler-with-cpp -std=c99 -P -o u-boot.lds /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/arch/arm/mach-zynq/u-boot.lds
| arm-xilinx-linux-gnueabi-ld.bfd -pie --gc-sections -Bstatic --no-dynamic-linker -Ttext 0x00400000 -o u-boot -T u-boot.lds arch/arm/cpu/armv7/start.o --start-group arch/arm/cpu/built-in.o arch/arm/cpu/armv7/built-in.o arch/arm/lib/built-in.o arch/arm/mach-zynq/built-in.o board/xilinx/zynq/built-in.o cmd/built-in.o common/built-in.o disk/built-in.o drivers/built-in.o drivers/dma/built-in.o drivers/gpio/built-in.o drivers/i2c/built-in.o drivers/mtd/built-in.o drivers/mtd/onenand/built-in.o drivers/mtd/spi/built-in.o drivers/net/built-in.o drivers/net/phy/built-in.o drivers/power/built-in.o drivers/power/battery/built-in.o drivers/power/domain/built-in.o drivers/power/fuel_gauge/built-in.o drivers/power/mfd/built-in.o drivers/power/pmic/built-in.o drivers/power/regulator/built-in.o drivers/serial/built-in.o drivers/spi/built-in.o drivers/usb/common/built-in.o drivers/usb/dwc3/built-in.o drivers/usb/emul/built-in.o drivers/usb/eth/built-in.o drivers/usb/gadget/built-in.o drivers/usb/gadget/udc/built-in.o drivers/usb/host/built-in.o drivers/usb/musb-new/built-in.o drivers/usb/musb/built-in.o drivers/usb/phy/built-in.o drivers/usb/ulpi/built-in.o env/built-in.o fs/built-in.o lib/built-in.o net/built-in.o --end-group arch/arm/lib/eabi_compat.o arch/arm/lib/lib.a -Map u-boot.map; true
| arm-xilinx-linux-gnueabi-ld.bfd: drivers/built-in.o: in function `mmc_block_op':
| /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/drivers/dfu/dfu_mmc.c:29: undefined reference to `find_mmc_device'
| arm-xilinx-linux-gnueabi-ld.bfd: /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/drivers/dfu/dfu_mmc.c:51: undefined reference to `mmc_get_blk_desc'
| arm-xilinx-linux-gnueabi-ld.bfd: /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/drivers/dfu/dfu_mmc.c:64: undefined reference to `mmc_get_blk_desc'
| arm-xilinx-linux-gnueabi-ld.bfd: /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/drivers/dfu/dfu_mmc.c:67: undefined reference to `mmc_get_blk_desc'
| arm-xilinx-linux-gnueabi-ld.bfd: drivers/built-in.o: in function `dfu_fill_entity_mmc':
| /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/drivers/dfu/dfu_mmc.c:327: undefined reference to `find_mmc_device'
| arm-xilinx-linux-gnueabi-ld.bfd: /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/drivers/dfu/dfu_mmc.c:334: undefined reference to `mmc_init'
| arm-xilinx-linux-gnueabi-ld.bfd: /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/drivers/dfu/dfu_mmc.c:357: undefined reference to `mmc_get_blk_desc'
| ERROR: oe_runmake failed
| make[1]: *** [/opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git/Makefile:1495: u-boot] Error 1
| make[1]: Leaving directory '/opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/build'
| make: *** [Makefile:148: sub-make] Error 2
| make: Leaving directory '/opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/git'
| WARNING: /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/temp/run.do_compile.23229:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /opt/pkg/petalinux/2019.1/plate_dem/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/temp/log.do_compile.23229)
ERROR: Task (/opt/pkg/petalinux/2019.1/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/u-boot/u-boot-xlnx_2019.1.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 4500 tasks of which 3421 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
alp_xilinx@alpxilinx-VirtualBox:/opt/pkg/petalinux/2019.1/plate_dem$
tmaintz
Great to hear! Have fun debugging
Please close the thread ;)
shabbirk
Hi @mspalpsahan
Try disabling DFU support in uboot and rebuild to see if these errors disappears:
petalinux-config -c u-boot
Device Drivers --->[] USB support ---> un select
2. Command line interface --> Device access commands --> [ ] usb -- Un select
        ---> [ ] dfu --- > un select
tmaintz
hi @mspalpsahan
do you have a zynq device? If yes: Did you configured an SD card on your MIO within the PS?
Could you provide a bit more information about your system?
Cheers
Thomas
mspalpsahan
hi
thank you for interested
its not working. please help me about petalinux compile
do you have a zynq device? yes i have two device ZYBO-z7-20. and custom pcb board with Z702 but i am use zybo-z7 -20 device
If yes: Did you configured an SD card on your MIO within the PS? yes configured
Could you provide a bit more information about your system? yes i provide a bit
I'm doing the following steps
Macine device name `zc702`
$ source settings.sh
$ echo $PETALINUX
output:
$ petalinux-create --type project --template zynq --name /plate_test
$ cd /plate_test
$ petalinux-config --get-hw-description=/home/alp_xilinx/public/Xilinx_peta/zybo_petalinux-master_usbcamera/zybo_petalinux-master/zybo_petalinux_webcam/zybo_petalinux_webcam.sdk/block_design_wrapper_hw_platform_1/
$ petalinux-config -c kernel
$ petalinux-config -c rootfs
$ petalinux-build
thank you
Alpaslan sahan
tmaintz
Your commands seem to be okay.
Which Ubuntu Version do you use? Do you have also Vivado 2019.1? Where does the build process fail?
mspalpsahan
hi
first, i use ubuntu 16.04 LTS in the virtual box. due to other problems i am use ubuntu 18.04.3 LTS now.
yes have vivado 2019.1
$ petalinux-build
output:
[INFO] building project
[INFO] sourcing bitbake
[INFO] generating user layers
INFO: bitbake petalinux-user-image
Loading cache: 100% |############################################| Time: 0:00:04
Loaded 3811 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:13
Parsing of 2777 .bb files complete (2776 cached, 1 parsed). 3812 targets, 163 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:16
Checking sstate mirror object availability: 100% |###############| Time: 0:01:09
Sstate summary: Wanted 194 Found 16 Missed 356 Current 1124 (8% match, 86% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: u-boot-xlnx-v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0 do_compile: oe_runmake failed
ERROR: u-boot-xlnx-v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0 do_compile: Function failed: do_compile (log file is located at /opt/pkg/petalinux/2019.1/plate_test/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/temp/log.do_compile.3185)
ERROR: Logfile of failure stored in: /opt/pkg/petalinux/2019.1/plate_test/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/temp/log.do_compile.3185
thank you very much
Alpaslan sahan
tmaintz
whats inside /opt/pkg/petalinux/2019.1/plate_test/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+d895ac5e94-r0/temp/log.do_compile.3185 ?
could you provide your uboot bbappend recipies?
mspalpsahan
hi
ok
file attachment.
thank you
Alpaslan sahan
tmaintz
please include the mmc command in the u-boot.
you can search for this by pressing "/" and type "mmc"
mspalpsahan
hi
i am sorry. i did not understand. could you send detail about mmc command
best regards
mspalpsahan
hi
ok. i did find mmc command. I can make build.
thank you very much
Alpalsan sahan
tmaintz
anmol_8496
this problem occur due to some package that not fit for the board. if you build project default configuration then you found it's working.
