flashcp BOOT.BIN won't fit into /dev/mtd0
Hi All,
When I used flashcp to copy the BOOT.BIN into mtd0, it gave me an error “won't fit into /dev/mtd0”.
My BOOT.BIN is a bit bigger than 1 MB which was set for mtd0.
Is there any way we can resize them?
Because it is the DUAL QSPI, is the total size of mtd0-mtd7 equal to 128MB?
Based on the current mtd size config of mtd0-mtd7, it is total of more than 128 MB.
Does it have to be 128 MB total?
Below is the MTDs size:
cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00100000 00002000 "qspi-fsbl-uboot"
mtd1: 00500000 00002000 "qspi-linux"
mtd2: 00020000 00002000 "qspi-device-tree"
mtd3: 005e0000 00002000 "qspi-rootfs"
mtd4: 01e00000 00002000 "boot"
mtd5: 00040000 00002000 "bootenv"
mtd6: 02400000 00002000 "kernel"
mtd7: 03dc0000 00002000 "spare"
Tuan
hi @tnguyen4447
Maybe you can change your partition size of flash in dts at Petalinux stage.
