Anonymous
Not applicable
frame buffer in microblaze
i'm using SP605 and a linux run on it(base on microblaze).then i want to add tft_ip into my project.
So i modify the menuconfig with:
# Graphics support
CONFIG_FB=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
# Frame buffer hardware drivers
CONFIG_FB_XILINX=y
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_LCD_CLASS_DEVICE=m
CONFIG_LCD_PLATFORM=m
CONFIG_BACKLIGHT_CLASS_DEVICE=m
CONFIG_BACKLIGHT_GENERIC=m
# Display device support
CONFIG_DISPLAY_SUPPORT=y
# Display hardware drivers
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_XILINX_EDK=y
but when i build the kernel, it says ' drivers/video/xilinxfb.c:37:21: error: asm/dcr.h: No such file or directory'
after searching that file,i find that it only exist in arch/powerpc and arch/sparc.
does it mean i can't use that with microblaze?or have i  do somehing wrong?
Regards.
