10-27-2012 05:50 PM
My Linux-kernel-newbie question pertains to Linux UserIO (UIO) based user mode device driver access to memory mapped PL devices.
I have Linaro Ubuntu Linux running on my ZedBoard. For starters I followed the directions here: http://wiki.analog.com/resources/tools-software/linux-drivers/platforms/...
I have also built a new Zynq system config with just one peripheral (a simple counter) in PL -- no display controller etc. I am able to read and write that counter from a standalone C program.
I am also able to boot Ubuntu Linux on that config. I changed my devicetree.dtb so it configures no (zero) PL based peripherals. It comes up nicely, network works, SD works, etc. It has no frame buffer / display but I can still get a GUI via remote desktop (by installing and running xrdp/xvnc). The nice thing about this set-up is I don't waste any PL on an extraneous display controller, etc. And I can travel and do GUI Zynq Linux development with just a laptop and the ZedBoard.
Running Linux, I am also able to talk to my counter peripheral directly, e.g. by opening /dev/mem, mmaping a view of memory on my counter's physical address, and reading and writing that. It works well. But it is hack. I hate opening /dev/mem. And it won't help when/if I start trying to send interrupts to my app.
I read about Linux UIO here: http://www.petalogix.com/support/kb/uio_howto That seems ideal for this device. Then my Linux app would simply open /dev/uio0 (for example), mmap a view on it, and wait for interrupts by reading from it.
UNfortunately I haven't been able to get UIO working. I edited my kernel configuration and enabled devices uio, uio_pdrv, uio_pdrv_genirq, and rebuilt it.
I also edited my devicetree .dts to add:
cnt0: cnt@7c800000 {
#address-cells = <1>;
#size-cells = <1>;
compatible = "generic-uio", "uio", "uio_pdrv";
reg = <0x7c800000 0x1000>;
When I boot this system, I see:
1. No uio device console message at boot time.
2. No /dev/uio0 (should I mknod it manually?)
3. /sys/class/uio exists, but is empty.
4. /proc/devices includes the uio device
I imagine my .dts is foobar but various tweaks of it do not improve the situation. I am going to dig into the kernel sources to see how the devicetree is processed but I was wondering:
1. Do you use UIO to write user-model device drivers?
2. Or do you prefer some other approach?
3. What should my DTS look like to enable UIO to a memory mapped device control register?
4. Do you have to manually mknod an entry for it in /dev/uio[0123]?
5. Do you have to do anything to set up /sys/class/uio/* ?
Thank you for any pointers.
10-28-2012 07:59 PM
I usually use just mmap of /dev/mem or a loadable module. This UIO thing sounds intriguing. Looks like the /dev/mem approach with some extra stuff for interrupts.
The Xilinx GIT and the mainline UIO code don't seem to have much device tree support. Linaro likely has a similar lack of device tree support. Perhaps the PetaLogix kernel has implemented complete device tree support. You might have to add a platform device to your board file.
03-21-2013 02:08 PM
I have exactly the same problem.
Have you been able to solve it?
I need to resolve this. Maybe we can help each other.
My email is pegroseo@gmail.com or pedro.duran@alumnos.usm.cl
03-21-2013 02:24 PM
I mean I saw this link: http://www.petalogix.com/support/kb/uio_howto and I did all it is there.
but then when boot linux on my atlys board there's nothing in /sys/class/uio so I can't use any application which calls to my peripherals, I tried with /dev/mem and everything works good but i read it's not a good idea to use it. it's a better idea to development with User IO. Please anybody! I'm stuck
03-27-2013 10:14 PM
The last time I checked the Xilinx Kernel did not have dts support for uio (yet). So you have to write a kernel module for uio. I attached mine to this post.
04-04-2013 03:56 PM - edited 04-04-2013 05:16 PM
I'm having the same issue. I have petalinux installed, and I'm using a ML605 board with a custom hardware platform that contains two GPIOs, one connected to the 8 LEDS and another to the Position LEDS of the board. I followed the tutorial in lab_1_5 from the Lab Documents & Presentations section at:
http://www.xilinx.com/university/workshops/embedded-linux-microblaze/. I am able to toggle the LEDS when I used the virtual memory file of the system and the xilinx modules, I tested it with the first half of lab_1_5 and the gpio_demo.
I setup the kernel to have the Userspace I/O drivers, I loading the module with modprobe, then listed the modules with lsmod, the following is the output with lsmod:
$lsmod
uio 6009 0 - Live 0xf005d000
My first question is: what is the value "0xf005d000"? I assume it is some address? But nothing in my dts file has this address in any device ranges. Can this be an issue?
The following is a snippet of my dts file. Note that I changed the label of the device label@XXXX, and changed the compatible to include "generic-uio" and "uio". I originally had "generic-uio", but it didn't work and I added "uio" but it still doesn't work.
leds_8bits: leds@40020000 { #gpio-cells = <2>; compatible="generic-uio","uio"; gpio-controller ; reg = < 0x40020000 0x10000 >; xlnx,all-inputs = <0x0>; xlnx,all-inputs-2 = <0x0>; xlnx,dout-default = <0x0>; xlnx,dout-default-2 = <0x0>; xlnx,family = "virtex6"; xlnx,gpio-width = <0x8>; xlnx,gpio2-width = <0x20>; xlnx,instance = "LEDs_8Bits"; xlnx,interrupt-present = <0x0>; xlnx,is-dual = <0x0>; xlnx,tri-default = <0xffffffff>; xlnx,tri-default-2 = <0xffffffff>; } ; leds_positions: leds0@40000000 { #gpio-cells = <2>; compatible="generic-uio","uio"; gpio-controller ; reg = < 0x40000000 0x10000 >; xlnx,all-inputs = <0x0>; xlnx,all-inputs-2 = <0x0>; xlnx,dout-default = <0x0>; xlnx,dout-default-2 = <0x0>; xlnx,family = "virtex6"; xlnx,gpio-width = <0x5>; xlnx,gpio2-width = <0x20>; xlnx,instance = "LEDs_Positions"; xlnx,interrupt-present = <0x0>; xlnx,is-dual = <0x0>; xlnx,tri-default = <0xffffffff>; xlnx,tri-default-2 = <0xffffffff>; } ;
The module is present in: /lib/modules/3.6.0/kernel/drivers/uio/uio.ko .
The previous post by nxdefiant mentioned that Xilinx does not have support for uio. But as I just mentioned I do have it. So, the only conclusions I came up with is: the module is loaded in an area that the kernel does not have access to it, or the module is wrong. If the module is incorrect/wrong, I can attempt to use the one posted by nxdefiant. But I am unafamiliar in creating a module in petalinux.
UPDATE: I am able to access the GPIO via the /dev/mem using the uio module.
Any suggestions or help would be appreciated. Thanks,
04-05-2013 10:06 PM
Bump! :)
04-24-2013 03:29 AM
Please note that I said that the Xilinx kernel doesn't have devicetree support for UIO yet*:
The UIO-Module is there, just no way to configure it with the dts file. Thats why I had to create the Module.
When using /dev/mem you are _not_ using UIO.
/dev/mem provides you with access to all physical memory which can be a security risk.
* The last time I checked was January, might be different now.
P.S: Yes I know this thread is a bit older, but it came up first on google for "zynq mmap".
05-28-2013 04:46 PM
I have finally figured this out to my satisfaction, and blogged 4000 words on it. I hope this helps.
http://fpgacpu.wordpress.com/2013/05/28/how-to-design-and-access-a-memory-mapped-device-part-one/
http://fpgacpu.wordpress.com/2013/05/28/how-to-design-and-access-a-memory-mapped-device-part-two/
Cheers.
08-09-2013 01:13 PM
Has anyone tried uio with 14.5 or later? I followed the instructions in the above blog and I can see the uio device, but any attempt to mmap it returns error 22 (invalid argument).
I am able to map the memory with /dev/mem and it behaves as expected, just not with uio, but I can't really use /dev/mem because I need interrupt support.
