how can I add libstdc++.so.6 to rootfs
Hi,all
my board is zc706
when I run c++ application on board, it print "error while shared libstdc++.so.6", there is no libstdc++.so.6 under /lib, so how can I add libstdc++.so.6 to my rootfs?
Tom
I copy libstdc++.so.6 from corss toolchain directory to my rootfs lib, and that worked!!!
check this post hopefully you will get answer for your query
https://forums.xilinx.com/t5/Embedded-Linux/problem-with-libstdc-so-6-Petalinux-2016-2/td-p/713921
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2014-4-SDK-includes-libstdc-but-build-does-not-add-to/td-p/601881
Thanks and Regards
Balkrishan
Thanks for your reply, the post https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2014-4-SDK-includes-libstdc-but-build-does-not-add-to/td-p/601881 said below:
Found that it helps if you actually include the libstdc++ in the rootfs config. Ran petalinux-config -c rootfs and enabled libstdc++6 in Filesystem Packages->base->external-xilinx-toolchain.
but in the petalinux2016.02, run "petalinux-config -c rootfs", there isn't the option "external-xilinx-toolchain"
would you please give me some hints, Thanks in advance
Tom
I have zcu102 with SDK 2018.2.
I need to copy two libs - libstdc++.so.6 and libgcc_s.so.1,
to  rootfs lib - it works now
