ronnywebers
Advisor
Advisor
how can I allocate and share a DDR4 memory buffer between Linux running on the PS and an AXI master controller in the PL ?
I want to build a custom IP with AXI master interface that reads a LUT from DDR4 memory. The LUT is initialized and/or updated from a linux application that runs on the A53 ARM cores.
I know how to build the custom IP. In a bare metal application, I know how to allocate a buffer at a fixed address (using linker file etc).
But I'm not sure how to allocate and share a part of the DDR4 memory  (in a safe way) with my IP in the PL when I'm running linux on the A53 ARM cores ... how do you allocate a fixed, contiguous buffer in DDR4 in Linux, how does the PL know the base address, ... is this accomplished through the device tree, or ?
Is there any example that shows how to do this?
watari
Hi @ronnywebers
Would you describe reserved memory in dts and use cma ?
https://www.kernel.org/doc/Documentation/devicetree/bindings/reserved-memory/reserved-memory.txt
Best regards,
