how can i config TTC?
I ues petalinux and 7z045ffg900-2 and the UG1144(2020.1 page 19) says
[One Triple Timer Counter (TTC) (required).]
I search it on google but not yield helpful anwser.
could you please tell me how can i meet this require.
HI @firesuiry
This has to be enabled in your vivado design. you can see this option in ps7 processing system wizard
I attached the screenshot for your reference.
Thanks & regards
Aravind
HI @firesuiry
Thanks & regards
Aravind
thank you!
