how to access DDR3 from Linux
I am using ZyncMP with zync102 board.
I want to read and write in to DDR3 memory from Linux , please suggest me how to read/write in to DDR3 memory.
Pushpendra
Re: how to access DDR3 from Linux
It's not clear what you mean. All your application in Linux exist in DDR and hence they read / write it
You can write directly to Ddr or any other memory mapped device in physical address space by using mmap on /dev/mem. But if the memory you are trying to write is not excluded from Linux or somehow reserved it might crash your Linux and causes undefined behavior.
@psk1801,
You can use devmem command to read/write[32-bit value] into ddr address.
if you want to write onto chunk of memory  then you have to do memory map the address range from user application.
Use below link on how to use mmap in linux.
http://man7.org/linux/man-pages/man2/mmap.2.html
Kranthi
Best Regards
Kranthi
You should review the following wiki page that talks about reserving chunks of memory so that the kernel will not use them.
http://www.wiki.xilinx.com/Linux+Reserved+Memory
