alishah
how to access led on microzed board through kernel space
I am using microzed board to boot linux from it and i am using petalinux tool to build my images. I want to glow an LED through kernel space. I am not sure where and in which file should i make a change so that i can glow LED through kernel space.
Please suggest me , what should i do for this problem?
thanks
sampatd
The Linux GPIO driver can be accessed by user space through sysfs file system. You should be able to see the controllers at /sys/class/gpio
For more information, check:
http://www.wiki.xilinx.com/Linux+GPIO+Driver
http://www.wiki.xilinx.com/GPIO+User+Space+App
alishah
@sampatd Thanks for your reply.
I want to access LED from kernel space and not from user's space.
can u tell me how and where to include the following function:
http://www.zilogic.com/releases/bsp-1.5.1/doc/zdev-user-manual/API-gpio-direction-output.html
you can find function gpio_direction_output() in this link .
Can i access and glow LED using this function?
If possible, please help me where to include this function and modification needed to be done
alishah
Can anyone help me regarding this query ?
rfs613
This is part of the Linux kernel GPIO framework.
See https://www.kernel.org/doc/Documentation/gpio/
in particular the files consumer.txt and gpio-legacy.txt
I do not know if the Zynq GPIOs work with this framework.
You could also consult the source code of the Xilinx GPIO driver module: https://github.com/Xilinx/linux-xlnx/blob/master/drivers/gpio/gpio-xilinx.c
-R
alishah
I have to access gpio pin 47 to glow LED on microzed board.
can i access this pin using the function: gpio_direction_output(unsigned gpio, int value)
                                                  gpio_direction_output(47,1);
 If possible, In which file can i include above function?
What other functions are required other than gpio_direction_output?
I want my LED glow after kernel boots and i want it from kernel space and not from users space
Please help me.
sampatd
I have not tried the above kernel API; however, if you use PetaLinux 2014.4, you can create the application and integrate it into the rootfs.
Once you have the application, you can auto run it on start up.
Please refer to ug1144 for more information:
http://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_4/ug1144-petalinux-tools-reference-guide.pdf
