how to add or modify petalinux 2016.4 yocto kernel source or devictree source?
i look for this question in the community for a day but found little answers.
iam  a  new to the yocto,and found it  was hard to use and maybe this is the same to the one who is not familiar with the layers of the yocto.
here is one answer.
https://forums.xilinx.com/t5/Embedded-Linux/How-can-I-modify-kernel-source-code-in-meta-xilinx-kernel/m-p/730920#M17336
but i not understand this.
and this is an other example https://community.nxp.com/docs/DOC-95252
Re: how to add or modify petalinux 2016.4 yocto kernel source or devictree source?
and for the kernel modify
after build the kernel you will find the source code in the
<plnx-proj-root>/build/tmp/work-shared/plnx_arm/kernel-source
1. modify the code source in the <plnx-proj-root>/build/tmp/work-shared/plnx_arm/kernel-source
for example: drivers/w1/masters/w1-gpio.c
2. in the  <plnx-proj-root>/build/tmp/work-shared/plnx_arm/kernel-source do like this
git add file1(like:drivers/w1/masters/w1-gpio.c) file2 ...
3. give a pacth tile
git commit -s -m 'your commit title'
4.create the pacth
git format-patch -1
    #and then you will see the .pacth in you current directory.
5. copy this .pacth to the <plnx-proj-root>/project-spec/meta-user/recipes-kernel/linux/linux-xlnx/
and add the linux-xlnx_%.bbappend file in the <plnx-proj-root>/project-spec/meta-user/recipes-kernel/linux/
like:
SRC_URI_append = " file://xxxx.patch"
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
and then
and then petaliunx-build
and the new <plnx-proj-root>/build/tmp/work-shared/plnx_arm/kernel-source code will add your patch.
and i think this will be helpful with you.
in the 2016.4 ug1144-petalinux-tools-reference-guide.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
you can find this:
Adding Patches to Source Repo
If the sources of a component is a git repo, you can apply patches on top of the repo.
An example to add patches for u-boot and to apply mypatch.patchis given below:
1. Copy the mypatch.patchto
<plnx-proj-root>/project-spec/meta-user/recipes-bsp/u-boot/files
2. Open
<plnx-proj-root>/project-spec/meta-user/recipes-bsp/u-boot/u-boo
t-xlnx_%.bbappend and add the following line:
SRC_URI_append = " file://mypatch.patch"
If there is no bbappend for a utility, you have to create bbappend for that utility on the
similar lines. An example for sample utility with mypatch.patchis shown below:
a. Create directory
<plnx-proj-root>/project-spec/meta-user/recipes-apps/sampleuti
lity/files/
b. Copy mypatch.patch to
lity/files/
c. Open
lity/sampleutility_%.bbappend and add the following line:
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
Yocto will apply the patch on the fetched git repo.
and i finally work it out like this
for device-tree i want to add a uart0 to the aliases like
model = "bus_standard";
aliases {
serial0 = &uart1;
serial1 = &uart0;
ethernet0 = &gem0;
chosen {
bootargs = "console=ttyPS0,115200 earlyprintk";
stdout-path = "serial0:115200ns";
memory {
device_type = "memory";
reg = <0x0 0x40000000>;
because the kernel will stop when boot in "console [ttyPS0] enable"
add this file to the
<plnx-proj-root>/project-spec/meta-user/recipes-dt/device-tree/files/
and in the <plnx-proj-root>/project-spec/meta-user/recipes-dt/device-tree/device-tree-generation_%.bbappend copy like this
SRC_URI_append ="\
file://system-top.dts\
file://system-conf.dtsi\
it is ok
.and it is also ok if you directly change the source file in the
<plnx-proj-root>/component/plnx_workspace/device-tree-generation/system-conf.dtsi
and ithink what ido in the <plnx-proj-root>/project-spec/meta-user/recipes-dt/device-tree directory
is to overwite the <plnx-proj-root>/component/plnx_workspace/device-tree-generation/system-conf.dtsi when build.
4.create the pacth
git format-patch -1
like:
and then
  As suggested, modifying the recipes and adding patches is the typical way but personally I find creating and maintaining patches a huge hassle.  If you have a private kernel repo, you just make you modifications in that repo and just create a recipe to use that private repo.   I keep my devicetree files in my private repo
  Also, this method allows you to just checkout just the kern repo and build it just using make.
jeff
it is truely very slow,when build the the kernel,as it will run the git every time you build.
but i think it is,as you siad, the   typical way may be  xilinx susggested, and it is new for petalinux 2016.4.
for 2016.3 there is the source code for xlnx-linux,but in 2016.4 you can not find the source code in the
petalinux intstall directory, just a lot git.and i am  not very suited .
Observer simalps
Make also sure to modify the priority for the meta-user layer to 7 in the project file <plnx-proj-root>/project-spec/meta-user/conf/layer.conf
see "Patching the Linux Kernel of a PetaLinux Project" in http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips
