liwenz
how to autostart source /mnt/petalinux/settings.sh on ubuntu
Every time, I have to key in  /mnt/petalinux/settings.sh. Could I auto start this command.
I google it, and add it to Startup applications, but I have nothing.
My linux is ubuntu 16.
aravindb
Hi @liwenz
Please add below line as  part  your .bashrc script.
vim ~/.bashrc
source /petalinux-v2016.4-final/settings.sh
Thanks & Regards
Aravind
aravindb
Hi @liwenz
vim ~/.bashrc
Thanks & Regards
Aravind
liwenz
Thanks, I got.
I tried it and worked well.
