abc123wyj
how to boot zynq-7000 from nand flash
hello all,
        my board inculdes XC7Z045-1FFG676C, SD cards and nand flash MT29F4G08ABBDAH4IT, I use petalinux create image.ub, zynq_fsbl.elf, u-boot.elf
then I use SDK create boot.bin
change the board into JTAG Mode, and program flash
after program successful, turn off power, change board into NAND flash Mood, and turn on power again, it shows:
In: serial
Out: serial
Err: serial
Net: No ethernet found.
U-BOOT for zynq7045_ps
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x820000, size 0x6000000
100663296 bytes read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
U-Boot-PetaLinux>
it can not boot linux correctly.
how to solve this problem?
I think it because nand flash does't have image.ub file. How to add image.ub into nand flash
petalinux-config shows below:
Looking forward to you reply. Thank you!
bog_dan
If you have the petalinux tools installed, you can use the petalinux-package command to build a boot.bin file with the kernel image built in without the SDK. You'll still use the SDK to program the flash.
petalinux-package --boot --fsbl <FSBL image> --fpga <FPGA bitstream> --u-boot --kernel
You should be able to add the image.ub in the create zynq boot with the rest of your files if you place it at the right offset. I've had issues that way, so I stick to the petalinux packager for ease.
bog_dan
fincs
abc123wyj
hi bog_dan,
   thank you for you reply. I use petalinux command to create boot.bin, and program nand flash
   it still shows can't get kernel image
   is there any config for linux boot correctly?
gudishak
Hi @abc123wyj,
Can you try creating a .bif file  with below syntax and run bootgen command Or you can create boot.bin from SDK tool.
the_ROM_image:
[bootloader] ./images/linux/zynq_fsbl.elf
./images/linux/download.bit(bitstream file)
./images/linux/u-boot.elf
./images/linux/image.ub
then try
bootgen -image newbif.bif -arch zynq -o boot.bin
Kranthi
Best Regards
Kranthi
abc123wyj
thank you for all your reply!
when create boot image in SDK with zynq_fsbl.elf, zynq_wrapper.bit, u-boot.elf, image.ub, I added offset in image.ub.
The offset calculated from the size of boot.bin add size of bootenv which set in the petalinux-config.
Then the linux can boot correctly!
