how to build u-boot for USB DFU
I use zynq7000(zedboard), clone u-boot source by git clone https://github.com/Xilinx/u-boot-xlnx.git. tag is xilinx-v2017.4.
Build u-boot by "make zynq_zed_config; make" before, it work fine.
Recently I want to add DFU support in u-boot, I have find almost support DFU features in zynq_zed_config, but when I start dfu featrue in u-boot, it doesn't work, any I missed?
here is my testing:
1. Start dfu "run dfu_ram", it report "Unknown command 'set' - try 'help'"
2. I look through the variables, it's "dfu_ram=run dfu_ram_info && dfu 0 ram 0" and "dfu_ram_info=set dfu_alt_info ......", I guess it may be setenv.
2. First "setenv dfu_alt_info '......'", it have no error
3. Then "dfu 0 ram 0", it report "g_dnl_register: failed!, error: -19 ......."
I have read the guide/post messages here, they are talking zynqmp and petalinux, but I didn't use petalinux to build, so I have no idea.
Anyone share some experience?
