how to build u-boot from existing files?
I have Device-tree.mss and HDF files . How can I build u-boot?
Re: how to build u-boot from existing files?
Hello @olkhramus,
You need to use a virtual drive formatted with a Linux/Unix file system.  Shared folders on Windows file systems do not support symbolic links in the same manner that Linux does.
Yes, some of the Windows file systems support symbolic links, but they are a nuissance to use, and I do not believe that "hgfs" will properly map them.
Good Luck!
Kind Regards,
Peimann, S. M.
Toddlers are the Storm-Troopers of the Great God Entropy.
Physics: Not Just a Good Idea, It's THE LAW.
Hi @olkhramus ,
You might need to export hdf to your petalinux project and build project. You will get images/linux/u-boot.elf binary at the end.
Please refer https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1144-petalinux-tools-reference-guide.pdf
on how to build petalinux project[u-boot] for reference
Best Regards
Kranthi
after the command :  petalinux-build -c bootloader I got the next messages . Can you advise?
Parsing of 2331 .bb files complete (2295 cached, 36 parsed). 2946 targets, 195 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
tar: ./x86_64-linux/lib/libanl.so.1: Cannot create symlink to 'libanl-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libutil.so.1: Cannot create symlink to 'libutil-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libnss_compat.so.2: Cannot create symlink to 'libnss_compat-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libcrypt.so.1: Cannot create symlink to 'libcrypt-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libBrokenLocale.so.1: Cannot create symlink to 'libBrokenLocale-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/librt.so.1: Cannot create symlink to 'librt-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libnss_files.so.2: Cannot create symlink to 'libnss_files-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libc.so.6: Cannot create symlink to 'libc-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libnss_dns.so.2: Cannot create symlink to 'libnss_dns-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/ld-linux-x86-64.so.2: Cannot create symlink to 'ld-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libm.so.6: Cannot create symlink to 'libm-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libmvec.so.1: Cannot create symlink to 'libmvec-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libresolv.so.2: Cannot create symlink to 'libresolv-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libdl.so.2: Cannot create symlink to 'libdl-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libpthread.so.0: Cannot create symlink to 'libpthread-2.23.so': Operation not permitted
tar: ./x86_64-linux/lib/libnsl.so.1: Cannot create symlink to 'libnsl-2.23.so': Operation not permitted
tar: ./x86_64-linux/usr/lib/libstdc++.so.6: Cannot create symlink to 'libstdc++.so.6.0.21': Operation not permitted
tar: ./x86_64-linux/etc/ld.so.cache: Cannot create symlink to '/etc/ld.so.cache': Operation not permitted
tar: Exiting with failure status due to previous errors
Traceback (most recent call last):
File "/media/sf_SharedUB/test_prj_1510/ZZ/build/tmp/sysroots-uninative/relocate_sdk.py", line 228, in <module>
perms = os.stat(e)[stat.ST_MODE]
OSError: [Errno 2] No such file or directory: '/media/sf_SharedUB/test_prj_1510/ZZ/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2'
Hello @olkhramus,
Are you running on a Linux file-system or a Windoze file-system?
Kind Regards,
Peimann, S. M.
Hi @olkhramus ,
Never install petalinux tools or build petalinux/yocto project on windows shared drive on VM's it may cause havoc in builds.
Sandeep
Indeed I'm using Oracle VM Virual Box 6.0 and Ubuntu 16.04  at  Windows 10 PC. Should I expect the problems with Petalinux 2016.4?
... and yes , I arranged the Petalinux project in the Shared folder....
Hello @olkhramus,
Good Luck!
Kind Regards,
Peimann, S. M.
