how to build uboot_bsp
hi,
I am trying to build uboot_bsp, and found the following description in WIKI, but I am not quite clear about how to do this,
1. how to install the uboot_bsp? I extract from the package and only found *.mld and *.tcl file.
2. how to create the u-boot bsp and compile it in SDK?
Re: how to build uboot_bsp
Hi @mcggoal
You have to add a new local repository in the SDK pointing to the u-boot BSP library. Once you have done you will be able to select U-Boot as BSP OS.
Ibai
Hi @mcggoal
1. To which wiki page are you referring?
2. Currently the recommended way to generate U-Boot binaries is Petalinux, so take a look to http://www.wiki.xilinx.com/PetaLinux
Ibai
Ibai
hi, @ibaie
I just ref to the "Building U-Boot" in this page:
http://www.wiki.xilinx.com/Build+U-Boot#MicroBlaze
Hi @mcggoal
Ibai
Newbie is_as_sasi
hi Ibaie
if possible can u plz tell me the exact directory in which *.mld and *.tcl file should be copied for 14.6 version
14.6\ISE_DS\EDK\sw\lib\bsp
I tried here but sdk was unable to detect
